I’m trying to add a bar coming off of the sides of my four bar that stays level the entire time but is mounted in the middle of the bar, how?
You could add another vertical bar in the center and T off of that. It will stay parallel with the ends.
Note: for hudson’s method to work, you MUST have the same spacing vertically and horizontally for your lift pivot points (a parallelogram, not a sorta-kinda parallelogram).
