#include “main.h”
- A callback function for LLEMU’s center button.
- When this callback is fired, it will toggle line 2 of the LCD text between
- “I was pressed!” and nothing.
void on_center_button() {
static bool pressed = false;
pressed = !pressed;
if (pressed) {
pros::lcd::set_text(2, “I was pressed!”);
} else {
pros::lcd::clear_line(2);
Runs initialization code. This occurs as soon as the program is started.
All other competition modes are blocked by initialize; it is recommended
to keep execution time for this mode under a few seconds.
void initialize() {
pros::lcd::initialize();
pros::lcd::set_text(1, “Hello PROS User!”);pros::lcd::register_btn1_cb(on_center_button);
- Runs while the robot is in the disabled state of Field Management System or
- the VEX Competition Switch, following either autonomous or opcontrol. When
- the robot is enabled, this task will exit.
void disabled() {}
- Runs after initialize(), and before autonomous when connected to the Field
- Management System or the VEX Competition Switch. This is intended for
- competition-specific initialization routines, such as an autonomous selector
- on the LCD.
- This task will exit when the robot is enabled and autonomous or opcontrol
- starts.
void competition_initialize() {}
- Runs the user autonomous code. This function will be started in its own task
- with the default priority and stack size whenever the robot is enabled via
- the Field Management System or the VEX Competition Switch in the autonomous
- mode. Alternatively, this function may be called in initialize or opcontrol
- for non-competition testing purposes.
- If the robot is disabled or communications is lost, the autonomous task
- will be stopped. Re-enabling the robot will restart the task, not re-start it
- from where it left off.
void autonomous() {}
- Runs the operator control code. This function will be started in its own task
- the Field Management System or the VEX Competition Switch in the operator
- control mode.
- If no competition control is connected, this function will run immediately
- following initialize().
- operator control task will be stopped. Re-enabling the robot will restart the
- task, not resume it from where it left off.
void opcontrol() {
pros::Motor left_mtr(20);
left_mtr.move_relative(1000,100);
if anyone could tell me how to put this in that box that would help. This simple code where it literally just moves 1000 units doesn’t work, in fact the motor doesn’t even make a sound, anyone find some issues with it?
