I have a question how can I make it where I can still move while running my shooter code This is how it looks now
if(Controller1.ButtonL1.pressing()) {
Shooter.setVelocity(95, percent);
Pusher.setVelocity(100,percent);
Shooter.spin(reverse);
wait(4,seconds);
Pusher.spin(reverse);
wait(1,seconds);
Pusher.spin(forward);
wait(1,seconds);
wait(1,seconds);
wait(1,seconds);
Pusher.stop();
Shooter.stop();
} else if (Controller1.ButtonL2.pressing()){
Shooter.spin(forward);
} else {
Shooter.stop();
That’s not really true, else if is more about allowing the first conditional test to have priority over the second. so in this case.
if (Controller1.ButtonL1.pressing()) {
// code
else
if (Controller1.ButtonL2.pressing()) {
// more code
} else {
// even more code
ButtonL1.pressing() will have priority over ButtonL2.pressing() if both are true. Without the else the poor motor may get conflicting commands if both buttons are pressed (which won’t happen with OP code due to all the waits in the first test)
The only thing I can think of would be to use a separate thread for the shooter code but I’m not quite sure how threads work so I am using the example and hoping I guessed how it works. Here is what I got.
/* Module: main.cpp */
/* Author: VEX */
/* Created: Sun Oct 06 2019 */
/* Description: This program will run a thread parallel (at the same time */
/* to main. */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Controller1 controller
// Shooter motor 1
// Pusher motor 2
#include "vex.h"
using namespace vex;
bool Stop = 0;
int myThreadCallback() {
//turns off ability to control shooter
Stop = 1;
wait(4,seconds);
wait(1,seconds);
wait(1,seconds);
wait(1,seconds);
wait(1,seconds);
Pusher.stop();
Shooter.stop();
//turns on ability to control shooter
Stop = 0;
//Might be left over from loop example but keep just in case
this_thread::sleep_for(25);
//ends the thread
return 0;
int main() {
vexcodeInit();
while(true){
if(Controller1.ButtonL1.pressing()){
//Not sure if this can be ran more than once since I can't test it
thread myThread = thread(myThreadCallback);
//won't run if the thread code is still running to avoid messing it up
else if(Controller1.ButtonL2.pressing() && !Stop){
else {
Shooter.stop();
wait(25, msec);
I am unsure if the wait command would work correctly in this way but no reason to not try it.
If someone knows how to make this better / work please share.
I would recommend using a function callback so the wait statements don’t interrupt your driving.
The code would look like this.
Inside main:
controller1.buttonL1.pressed(fireShooter)
Outside main as a function
void fireShooter(){
The code to shoot goes here
Does a callback make a separate task for the function it calls? Cause if it doesn’t then the wait timers would still affect the driving
Alright so I have had the chance to test it myself and I found that you would probably want a latch in there as well to keep it from starting the thread 100 times from one push, here is the new code.
/* Author: NinjaPenguin16 */
/* Created: 1/12/2023 */
/* to main. */
// Shooter motor 1
// Pusher motor 2
#include "vex.h"
bool Stop = 0;
Stop = 1;
wait(4,seconds);
wait(1,seconds);
wait(1,seconds);
wait(1,seconds);
wait(1,seconds);
Pusher.stop();
Shooter.stop();
Stop = 0;
this_thread::sleep_for(20);
//ends the thread
return 0;
bool latchL1 = 0;
bool toggleL1 = 0;
int main() {
vexcodeInit();
while(true){
//Starts thread and puts down latch when L1 pushed
if(Controller1.ButtonL1.pressing() && !latchL1){
latchL1 = true;
else if(!Controller1.ButtonL1.pressing() && latchL1){
latchL1 = false;
else {
Shooter.stop();
wait(20, msec);
Only trouble you should have now is integrating it into your code.
It does make a seperate task and is much simpler than creating a thread.
nice, thanks for the clarification
You would need to add a way for it to disable user control of the launcher while the callback is running though right? So you can’t accidentally mess it up?
