MoveTo function only running latest instance
In python, I have the following piece of code in Vex VR:
PMX = PMY = 1
def P(v: float): return 24*v
# gps.set_location(PMX * P(-2.5), PMY * P(-1.5), INCHES)
def MoveTo(x, y, reverse=False):
    [yDif, xDif] = [P(y*PMY)-gps.y_position(INCHES), P(x*PMX)-gps.x_position(INCHES)]
    K1 = math.atan2(yDif, xDif)*180/math.pi
    K2 = (math.pi - math.atan2(yDif, abs(xDif)))*180/math.pi
    angle = K1 if xDif >= 0 else K2
    drivetrain.turn_to_heading(-angle, DEGREES)
    drivetrain.drive_for(REVERSE if reverse else FORWARD, math.sqrt(xDif**2 + yDif**2), INCHES)
MoveTo(0,-2,0,0)
# MoveTo(-2.5,-0.5,0,0)
This code allows you to go to any location on the V5 High Stakes Field by tile-coordinates (1 tile coord per 24 inches), where (0,0) is the center of the field.
The line MoveTo(0,-2,0,0) allows you to go to the spot directly beneath the ladder (you can run the code yourself and see)
However, if you uncomment the last line,
It will go directly to (-2.5,-0.5) instead of (0,-2), then (-2.5,-0.5).
Can you please help me fix this issue?
Thanks.
Oops, it’s in the Rapid Relay Category. Can a moderator move it to High Stakes? Thanks.
I tried out your code and got the same thing, moving the function calls inside the main function like this fixed it for me:
def main():
    MoveTo(0,-2)
    MoveTo(-2.5,-0.5)
vr_thread(main)
Also side note it looks like you have too many parameters when you call MoveTo
Those are for my original code, where those extra parameters are relative coordinates if the quality is < 60.
