My Auton is not working
This post was flagged by the community and is temporarily hidden.
It appears your keyboard is broken, that might be the cause of your code not working.
Here’s an idea- maybe post the code that doesn’t work so we CAN help you!
void autonomous(void) {
// Insert autonomous user code here.
rotDRIVE(3.85841544524, true);
rotturnLEFT(0.25, true);
rotDRIVE(1.34, true);
rotturnRIGHT(0.25, true);
rotDRIVE(2.35, true);
rotturnLEFT(1, true);
//Adjust the values when we test
/10/31/2021/
//We need to get the auton on
rotDRIVE and rotTURN are functions
you should post those as well.
Also, what does you robot do when you run your autonomous ?
did you custom make a rotDrive and rotturn function?
