This is my code but my autonomous won’t run and I don’t know why.
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// RM motor 8
// RF motor 20
// RB motor 18
// LM motor 5
// LF motor 2
// LB motor 3
// Clamp digital_out D
// Controller1 controller
// back digital_out A
// LeftArm motor 4
// RightArm motor 9
// Ring motor 10
#include "vex.h"
using namespace vex;
competition Competition;
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton(void) {
vexcodeInit();
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void autonomous(void) {
RF.setVelocity(100,percent);
RB.setVelocity(100,percent);
RM.setVelocity(100,percent);
LF.setVelocity(100,percent);
LB.setVelocity(100,percent);
LM.setVelocity(100,percent);
Clamp.set(true);
vex::task::sleep(1000);
RF.startRotateFor(vex::directionType::rev, 700, vex::rotationUnits::deg);
RM.startRotateFor(vex::directionType::fwd, 700, vex::rotationUnits::deg);
RB.startRotateFor(vex::directionType::rev, 700, vex::rotationUnits::deg);
LF.startRotateFor(vex::directionType::rev, 700, vex::rotationUnits::deg);
LM.startRotateFor(vex::directionType::fwd, 700, vex::rotationUnits::deg);
LB.startRotateFor(vex::directionType::rev, 700, vex::rotationUnits::deg);
Clamp.set(false);
vex::task::sleep(500);
LF.startRotateFor(vex::directionType::fwd, 500, vex::rotationUnits::deg);
LM.startRotateFor(vex::directionType::rev, 500, vex::rotationUnits::deg);
LB.startRotateFor(vex::directionType::fwd, 500, vex::rotationUnits::deg);
RF.startRotateFor(vex::directionType::fwd, 500, vex::rotationUnits::deg);
RM.startRotateFor(vex::directionType::rev, 500, vex::rotationUnits::deg);
RB.startRotateFor(vex::directionType::fwd, 500, vex::rotationUnits::deg);
// Insert autonomous user code here.
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
RM.stop(vex::brakeType::hold);
RB.stop(vex::brakeType::hold);
RF.stop(vex::brakeType::hold);
LF.stop(vex::brakeType::hold);
LB.stop(vex::brakeType::hold);
LM.stop(vex::brakeType::hold);
// Prevent main from exiting with an infinite loop.
while (true) {
RB.spin(vex::directionType::fwd, (Controller1.Axis3.position() - Controller1.Axis1.value())/1, vex::velocityUnits::pct);
RF.spin(vex::directionType::fwd, (Controller1.Axis3.position() - Controller1.Axis1.value())/1, vex::velocityUnits::pct);
RM.spin(vex::directionType::fwd, (Controller1.Axis3.position() - Controller1.Axis1.value())/1, vex::velocityUnits::pct);
LM.spin(vex::directionType::fwd, (Controller1.Axis3.position() + Controller1.Axis1.value())/1, vex::velocityUnits::pct);
LB.spin(vex::directionType::fwd, (Controller1.Axis3.position() + Controller1.Axis1.value())/1, vex::velocityUnits::pct);
LF.spin(vex::directionType::fwd, (Controller1.Axis3.position() + Controller1.Axis1.value())/1, vex::velocityUnits::pct);
if (Controller1.ButtonUp.pressing()) {
back.set(true);
else if(Controller1.ButtonDown.pressing()){
back.set(false);
if (Controller1.ButtonR2.pressing()) {
Clamp.set(true);
else{
Clamp.set(false);
if (Controller1.ButtonR1.pressing() ) {
Ring.spin(vex::directionType::rev, 100, vex::velocityUnits::pct);
else if (Controller1.ButtonRight.pressing()) {
Ring.spin(vex::directionType::fwd, 100, vex::velocityUnits::pct);
else{
Ring.stop(vex::brakeType::hold);
if (Controller1.ButtonL1.pressing()) {
LeftArm.spin(vex::directionType::fwd,80, vex::velocityUnits::pct);
RightArm.spin(vex::directionType::fwd,80, vex::velocityUnits::pct);
else if (Controller1.ButtonL2.pressing()) {
LeftArm.spin(vex::directionType::rev, 80, vex::velocityUnits::pct);
RightArm.spin(vex::directionType::rev, 80, vex::velocityUnits::pct);
else{
LeftArm.stop(vex::brakeType::hold);
RightArm.stop(vex::brakeType::hold);
wait(100, msec);
Edit: code tags added by mods, please remember to use them.
