My Battery is funky
my teams battery cannot withstand being unplugged for more than 20 seconds on full battery. i tried hitting the reset hole with a pointed object, and now there is a strang lighting pattern like:
:red_circle::black_circle::black_circle::green_circle:*
*green on and off per second but red is on not blinking
Best to contact official vex support here: Sales & Support - VEX Robotics
You’ll get the best answer quickest that way.
Please refer to this article: https://kb.vex.com/hc/en-us/articles/360035590212-Using-the-V5-Battery-Medic
Batteries are pretty expensive to just randomly be poking the reset before even trying to determine what the problem might be.
The light problem is common and can happen. Plugging the battery in should fix it. If it is dying fast, there is probably a circuit problem in the battery.
There is also this article: https://kb.vex.com/hc/en-us/articles/360035589652-Interpreting-V5-Battery-Lights-and-Errors from the VEX Library that provides a helpful guide for interpreting the different battery light patterns like yours.
Probably this from the page linked above.
Understand when the battery shows the red LED with any of the green LEDs briefly flashing (once per second), an internal cell failure has been detected and the battery is essentially dead.
Time to recycle that one.
This happened to one of my friends. They just deemed it a bad battery and ordered some new ones. Over time, batteries do give in a bit slowly.
