My drivetrain isnt working during autonomous
I keep trying to use this code but the drivetrain isnt working during autonomous but it works during driver controll
#include "vex.h"
using namespace vex;
competition Competition;
int Brain_precision = 0, Console_precision = 0, Controller1_precision = 0;
float Uoss, Switch1, Switch2, Switch3, Switch4, Switch5, Switch6;
bool stopvision;
float ControllerScreen[3];
brain Brain;
controller Controller1 = controller(primary);
digital_out DigitalOutH = digital_out(Brain.ThreeWirePort.H);
motor leftMotorA(PORT1, ratio18_1, false);
motor Arm(PORT7, ratio18_1, false);
motor Intake(PORT12, ratio18_1, false);
motor leftMotorB(PORT2, ratio18_1, false);
motor leftMotorC(PORT5, ratio18_1, false);
motor_group LeftDriveSmart(leftMotorA, leftMotorB, leftMotorC);
motor rightMotorA(PORT3, ratio18_1, true);
motor rightMotorB(PORT4, ratio18_1, true);
motor rightMotorC(PORT6, ratio18_1, true);
motor_group RightDriveSmart(rightMotorA, rightMotorB, rightMotorC);
inertial TurnGyroSmart(PORT20);
smartdrive Drivetrain(LeftDriveSmart, RightDriveSmart, TurnGyroSmart, 319.19, 320, 40, mm, 1);
event Startvision = event();
event message1 = event();
event wait5 = event();
int onauton_autonomous_0() {
  Controller1.rumble(rumbleLong);
  Drivetrain.driveFor(forward,10,inches);
  Drivetrain.setHeading(0.0, degrees);
  Drivetrain.setStopping(hold);
  Drivetrain.setDriveVelocity(25.0, percent);
  Drivetrain.drive(reverse);
  Drivetrain.stop();
  Drivetrain.turnToHeading(335.0, degrees, true);
  wait5.broadcast();
  wait(1.3, seconds);
  Drivetrain.stop();
  Drivetrain.driveFor(reverse, 12.0, inches, true);
  Drivetrain.turnToHeading(284.0, degrees, true);
  Intake.setVelocity(70.0, percent);
  Intake.spin(forward);
  return 0;
// "when Controller1 ButtonR1 pressed" hat block
void onevent_Controller1ButtonR1_pressed_0() {
  if (Uoss == 0.0 || Uoss == 2.0) {
    Intake.setVelocity(60.0, percent);
    Intake.spin(reverse);
    Uoss = 1.0;
  else {
    Intake.stop();
    Uoss = 0.0;
void onevent_Controller1ButtonRight_pressed_0() {
  Arm.spinFor(forward,58,degrees);
void onevent_Controller1ButtonLeft_pressed_0() {
  Intake.spinFor(reverse,130,degrees);
  Intake.stop();
// "when Controller1 ButtonR2 pressed" hat block
void onevent_Controller1ButtonR2_pressed_0() {
  if (Uoss == 0.0 || Uoss == 1.0) {
    Uoss = 2.0;
  else {
    Intake.stop();
    Uoss = 0.0;
// "when I receive wait5" hat block
void onevent_wait5_0() {
  wait(1.0, seconds);
  DigitalOutH.set(true);
// "when started" hat block
int whenStarted2() {
  Arm.setStopping(hold);
  Uoss = 0.0;
  Switch1 = 0.0;
  Switch2 = 0.0;
  Switch3 = 0.0;
  Switch4 = 1.0;
  return 0;
// "when Controller1 ButtonL1 pressed" hat block
void onevent_Controller1ButtonL1_pressed_0() {
  if (Switch1 == 0.0) {
    Switch1 = 1.0;
  else {
    DigitalOutH.set(false);
    Switch1 = 0.0;
// "when driver control" hat block
int ondriver_drivercontrol_0() {
  Switch6 = 2.0;
  return 0;
// "when Controller1 ButtonUp pressed" hat block
void onevent_Controller1ButtonUp_pressed_0() {
  Switch2 = 1.0;
  while (!(Switch2 == 0.0)) {
    Arm.setVelocity(50.0, percent);
    Arm.spin(forward);
  wait(5, msec);
  Arm.stop();
// "when Controller1 ButtonUp released" hat block
void onevent_Controller1ButtonUp_released_0() {
  Switch2 = 0.0;
// "when Controller1 ButtonDown released" hat block
void onevent_Controller1ButtonDown_released_0() {
  Switch3 = 0.0;
// "when Controller1 ButtonDown pressed" hat block
void onevent_Controller1ButtonDown_pressed_0() {
  Switch3 = 1.0;
  while (!(Switch3 == 0.0)) {
    Arm.spin(reverse);
  wait(5, msec);
  Arm.stop();
int whenStarted3() {
  while (true) {
    if (Intake.temperature(percent) == 2.0) {
      ControllerScreen[static_cast<int>(2) - 1] = 1;
      Controller1.Screen.setCursor(Controller1.Screen.row(), 1);
      Controller1.Screen.setCursor(2, 1);
      Controller1.Screen.print("Intake Disconnected");
      Controller1.Screen.clearLine(2);
    } else if (Intake.temperature(percent) > 69.0) {
      Controller1.Screen.print("Intake Overheating");
    } else {
      ControllerScreen[static_cast<int>(2) - 1] = 0;
  wait(5, msec);
  return 0;
int whenStarted1() {
  Brain.Screen.drawImageFromFile("What.png", 0, 0);
  while (true) {
    if (Controller1.Axis2.position() > -5 || Controller1.Axis2.position() < 5) {
      RightDriveSmart.setVelocity(Controller1.Axis2.position(),percent);
      RightDriveSmart.spin(forward);
  return 0;
int whenStarted6() {
  while (true) {
    if (Controller1.Axis3.position() > -5 || Controller1.Axis3.position() < 5) {
      LeftDriveSmart.setVelocity(Controller1.Axis3.position(),percent);
      LeftDriveSmart.spin(forward);
  return 0;
int whenStarted4() {
  Controller1.Screen.clearScreen();
  ControllerScreen[0] = 0.0;
  ControllerScreen[1] = 0.0;
  ControllerScreen[2] = 0.0;
  while (true) {
    if (Arm.temperature(percent) == 2.0) {
      ControllerScreen[static_cast<int>(3) - 1] = 1;
      Controller1.Screen.setCursor(3, 1);
      Controller1.Screen.print("Arm Disconnected");
      Controller1.Screen.clearLine(3);
    } else if (Arm.temperature(percent) > 69.0) {
      Controller1.Screen.print("Arm Overheating");
    } else {
      ControllerScreen[static_cast<int>(3) - 1] = 0;
  wait(5, msec);
  return 0;
// "when Controller1 ButtonY pressed" hat block
void onevent_Controller1ButtonY_pressed_0() {
  Brain.Screen.drawImageFromFile("What.png", 0,0);
// Used to find the format string for printing numbers with the
// desired number of decimal places
const char* printToController1_numberFormat() {
  // look at the current precision setting to find the format string
  switch(Controller1_precision){
    case 0:  return "%.0f"; // 0 decimal places (1)
    case 1:  return "%.1f"; // 1 decimal place  (0.1)
    case 2:  return "%.2f"; // 2 decimal places (0.01)
    case 3:  return "%.3f"; // 3 decimal places (0.001)
    default: return "%f"; // use the print system default for everthing else
void VEXcode_driver_task() {
  // Start the driver control tasks....
  vex::task drive0(ondriver_drivercontrol_0);
  while(Competition.isDriverControl() && Competition.isEnabled()) {this_thread::sleep_for(10);}
  drive0.stop();
  return;
void VEXcode_auton_task() {
  // Start the auton control tasks....
  vex::task auto1(onauton_autonomous_0);
  while(Competition.isAutonomous() && Competition.isEnabled()) {this_thread::sleep_for(10);}
  auto1.stop();
  return;
int main() {
  vex::competition::bStopTasksBetweenModes = false;
  Competition.autonomous(VEXcode_auton_task);
  Competition.drivercontrol(VEXcode_driver_task);
  vexcodeInit();
  // register event handlers
  Controller1.ButtonR1.pressed(onevent_Controller1ButtonR1_pressed_0);
  Controller1.ButtonR2.pressed(onevent_Controller1ButtonR2_pressed_0);
  wait5(onevent_wait5_0);
  Controller1.ButtonL1.pressed(onevent_Controller1ButtonL1_pressed_0);
  Controller1.ButtonUp.pressed(onevent_Controller1ButtonUp_pressed_0);
  Controller1.ButtonUp.released(onevent_Controller1ButtonUp_released_0);
  Controller1.ButtonDown.released(onevent_Controller1ButtonDown_released_0);
  Controller1.ButtonDown.pressed(onevent_Controller1ButtonDown_pressed_0);
  Controller1.ButtonRight.pressed(onevent_Controller1ButtonRight_pressed_0);
  Controller1.ButtonY.pressed(onevent_Controller1ButtonY_pressed_0);
  Controller1.ButtonLeft.pressed(onevent_Controller1ButtonLeft_pressed_0);
  wait(15, msec);
  vex::task ws0(whenStarted1);
  vex::task ws1(whenStarted2);
  vex::task ws2(whenStarted3);
  vex::task ws3(whenStarted4);
  vex::task ws5(whenStarted6);
edit: code tags added by mods, please remember to use them
in the code editors made by vex, there is an example of how to set it up to work with the field control called “competition template”. put your auton and driver control into their respective functions and it should work.
The problem is that the 6 motor drive train isn’t working, It starts but the drive train doesn’t move
I believe the motor, motor group, and smartdrive syntax is
// Create the left Motors and group them under the
// motor_group "leftMotors".
motor leftMotorA = motor(PORT1, false);
motor leftMotorB = motor(PORT2, false);
motor_group leftMotors = motor_group(leftMotorA, leftMotorB);
// Create the right Motors and group them under the
// MotorGroup "rightMotors".
motor rightMotorA = motor(Ports.PORT3, true);
motor rightMotorB = motor(Ports.PORT4, true);
motor_group rightMotors = motor_group(rightMotorA, rightMotorB);
// Create the Inertial Sensor
inertial Inertial = inertial(PORT5);
// Construct a 4-Motor smartdrive "Smartdrive" with the
// smartdrive class.
smartdrive Smartdrive = smartdrive(leftMotors, rightMotors, Inertial, 259.34, 320, 40, mm, 1);
(from SmartDrive Functionality in VEX V5 C++ | Comprehensive Guide — VEXcode Documentation)
