#pragma config(Motor, port2, motorRIGHT, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port3, motorLEFT, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port4, motorARM, tmotorVex269_MC29, openLoop)
#pragma config(Motor, port5, motorWHEEL, tmotorVex269_MC29, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task main()
while(1==1)
{ motor[motorLEFT] = vexRT[Ch3];
motor[motorRIGHT] = vexRT[Ch2];
if(vexRT[Btn6U] == 1)
motor[motorARM] = 127;
else if (vexRT[Btn6D] == 1)
motor[motorARM] = -127;
else
motor[motorARM] = 0;
if(vexRT[Btn5U] == 1)
motor[motorWHEEL] = 127;
else if (vexRT[Btn5D] == 1)
motor[motorWHEEL] = -127;
else
motor[motorWHEEL] = 0;
It appears to me like a couple of your if statements do not have closing brackets. This could be the problem.
Your else if statements have no closing curly brackets
You’re actually missing 2 closing curly brackets at the end… ones for your while loop and task main.
Where should i add the brackets?
Put the 2 closing curly brackets at the very bottom of the code. They correspond to the task and the while loop. All of your if and if/else have corresponding open and close brackets so they’re good.
Others have done an excellent job of helping out. For anyone else having a related problem, make sure that all of your starting curly bracket and parantheses have a corresponding ending curly bracket or paranthesis. A fast way to check is by putting your cursor next to the curly bracket - your IDE should automatically highlight the corresponding one in your code.
Also, a note about debugging. If you run your code and see an error, oftentimes the error explains what is happening. When I ran your code, for example, I see the following message:
src/main.cpp:33:2: note: to match this '{'
src/main.cpp:69:4: error: expected '}'
Even though the exact wording may be a bit confusing at times, it’s usually possible to get a good idea of what’s causing the problem. Here, it seems like my opening curly bracket on line 33 expects a closing curly bracket, which is exactly what others identified.
