void autonomous() {
intake.spin(forward, 200, rpm);
this is the code we have but it wont work for some reason
void autonomous() {
You need to be using āintake.spinForā instead of āintake.spinā
You need to change ārpmā with ādegreesā
we tried thisā¦
void autonomous() {
intake.spinFor(forward, 200, degrees);
and there were no errors but still the robot didnāt move
we tried this
intake.spin(forward, 12.0, volt)
and the motor twitched a little bit, thatās what we have so far
Could we see the entire code, not just the autonomous? Most likely the problem is somewhere else.
This is c++ correct?
sure, this is our main.cpp file
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
#include "vex.h"
#include "robot-config.h"
using namespace vex;
competition Competition;
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton(void) {
vexcodeInit();
rise.set(true);
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
//motor intake = motor(PORT1, ratio18_1, true);
void autonomous() {
intake.spin(forward, 12, volt);
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
Sorry this reply is from a different account, iām one of the post creatorās teammates
yes, we are using C++ with the vex extension on vs code
You may need to include something else and possibly check if the command is right.
Take this with a grain of salt as i am not familiar with the vex C++ extension
