My radio is permanently blinking red. My brain can’t run tasks unless the controller is not connected to it. My brain also automatically starts the first program whenever it is turned on.
My brain software somehow got corrupted and is now inoperable. Any suggestions?
I would try connecting the brain to a computer running Windows or MacOS and run the V5 firmware utility (found here). I don’t have any clue if it will solve the problem, but it’s a good first step.
Already tried it, reset all settings only resets the shown settings on the screen, and delete programs didn’t work either. Unfortunately neither are hard resets.
Well, both are hard resets for their respective areas.
So you are saying that “Delete Programs” has left one or more programs on the brain ? Were they VEXcode programs ?
Do you mean that it goes to the Drive screen and shows Run button etc. or do you mean it actually runs the program, timer counts etc.
We have a setting to go to the Drive screen rather than the home screen, but that should be cleared by “Reset all Settings”, that’s the “Start At:” setting. But, as far as I can remember, we don’t even have the ability to run the default drive code when the brain powers up.
If you have the same problem as OP and followed all the steps described, James Pearman has given sound advice for next step with said issue - contact VEX Support. They will then be able to arrange replacement V5 Brain if it is hardware error.
A bit late, I still have the problem but I know it is definitely due to the program. My biggest suspicion is that it has to do with how vcs handle dynamic memory allocation (vectors/new). I really want to test this but I don’t have a vex brain
Did you add anything like that to your program? Otherwise the changes I made that led to this bug was adding 1 more task and adding another class.
