Bug.iqblocks (28.0 KB)
The attached project fails to download with
windows build for platform vexiq
"CXX src/main.cpp"
src/main.cpp:58:25: error: use of undeclared identifier 'Drive_Forward_Distance_Velocity__Velocity'; did you mean 'Drive_Right_Distance_Velocity__Velocity'?
BackMotor.setVelocity(Drive_Forward_Distance_Velocity__Velocity, percent); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Drive_Right_Distance_Velocity__Velocity src/main.cpp:57:91: note: 'Drive_Right_Distance_Velocity__Velocity' declared here void Drive_Right_Distance_Velocity(double Drive_Right_Distance_Velocity__Distance, double Drive_Right_Distance_Velocity__Velocity) { ^
src/main.cpp:59:26: error: use of undeclared identifier 'Drive_Forward_Distance_Velocity__Velocity'; did you mean 'Drive_Right_Distance_Velocity__Velocity'?
FrontMotor.setVelocity(Drive_Forward_Distance_Velocity__Velocity, percent); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Drive_Right_Distance_Velocity__Velocity src/main.cpp:57:91: note: 'Drive_Right_Distance_Velocity__Velocity' declared here void Drive_Right_Distance_Velocity(double Drive_Right_Distance_Velocity__Distance, double Drive_Right_Distance_Velocity__Velocity) { ^
src/main.cpp:74:33: error: use of undeclared identifier 'Drive_Forward_Distance_Velocity__Velocity'; did you mean 'Drive_Left_Distance_Velocity__Velocity'?
BackMotor.setVelocity((-1.0 * Drive_Forward_Distance_Velocity__Velocity), percent); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Drive_Left_Distance_Velocity__Velocity src/main.cpp:73:89: note: 'Drive_Left_Distance_Velocity__Velocity' declared here void Drive_Left_Distance_Velocity(double Drive_Left_Distance_Velocity__Distance, double Drive_Left_Distance_Velocity__Velocity) { ^
src/main.cpp:75:34: error: use of undeclared identifier 'Drive_Forward_Distance_Velocity__Velocity'; did you mean 'Drive_Left_Distance_Velocity__Velocity'?
FrontMotor.setVelocity((-1.0 * Drive_Forward_Distance_Velocity__Velocity), percent); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Drive_Left_Distance_Velocity__Velocity src/main.cpp:73:89: note: 'Drive_Left_Distance_Velocity__Velocity' declared here void Drive_Left_Distance_Velocity(double Drive_Left_Distance_Velocity__Distance, double Drive_Left_Distance_Velocity__Velocity) { ^
4 errors generated.
make: *** [vex/mkrules.mk:13: build/src/main.o] Error 1
make process closed with exit code : 2
