Namespaces not allowed in Vex V5 text?
Hi, I have a struct inside of a namespace and when I try to use the struct in any capacity, it says both the namespace and the struct don’t exist. However if I put the struct outside of the namespace it works fine. I’m currently using an outside library (it is only raw c++ 17 so I thought it would work fine on Vex). Is there any explanation for this? If I can’t use namespaces that’s a very strange, specific thing to ban. Thank you.
Namespaces work perfectly fine for me, you are likely doing something incorrectly. Could you please share your code?
namespace MathThings {
using RndGenerator = std::mt19937_64; //Mersenne Twister Algorithm, defining this makes it act like srand(time(0) and using it like RndEngine() is rand()
struct MathConstants {
          static constexpr float Delta = 0.2f;
Neither MathThings nor MathThings::MathConstants exists.
The code you sent builds for me without any issues.
#include "vex.h"
using namespace vex;
  //using RndGenerator = std::mt19937_64; //Mersenne Twister Algorithm, defining this makes it act like srand(time(0) and using it like RndEngine() is rand()
int main() {
  vexcodeInit();
  MathThings::MathConstants x;
What is the error message that you are getting?
Never mind, apparently even though I looked directly at the header file name letter for letter and typed it, I still made a typo. -_- I am going to be using std::clamp though, and it’s only c++ 17 onwards, so how can I make the IDE go to c++17?
I am not aware of any method to upgrade to c++ 17. However, you can create your own clamp method using something like this:
template <typename T>
T clamp(const T& n, const T& lower, const T& upper) {
  return std::max(lower, std::min(n, upper));
From this stack overflow post
Edit:
According to this post by jpearman, it should be possible to use c++ 17, but it seems like its untested and will likely cause you more trouble than its worth. I would recommend just making your own implementations for the methods that you need to use.
