I am not a very clean coder, and this has a lot of unnecessary code in it. I used a weird approach to an extremely simple bang bang, which worked well enough for us (4bps mid and bar). Unfortunately we were not the best at driving it and failed at our states competition.
#pragma config(Sensor, dgtl11, wheelEncoder, sensorQuadEncoder)
#pragma config(Motor, port1, Intake, tmotorVex393_HBridge, openLoop)
#pragma config(Motor, port2, TRL, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port3, TL, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port4, BRL, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port5, BL, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port6, TR, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port7, TLL, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, BR, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port9, BLL, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port10, Convey, tmotorVex393_HBridge, openLoop, reversed)
int target=0; //define target and rpm at global level so it can be passed between tasks
//int motorSpeed=0;
float rpm;
int lesser;
int higer;
int normal;
int currentEncoder; //Define variables to use
int previousEncoder;
int deltaEncoder;
int currentTime;
int previousTime;
int deltaTime;
task speedCalculate(); //define task(s) to be used
#pragma platform(VEX)
//Competition Control and Duration Settings
#pragma autonomousDuration(15)
#pragma userControlDuration(105)
#include "Vex_Competition_Includes.c" //Main competition background code...do not modify!
void pre_auton()
task autonomous()
while(true){
motor[TLL] = -91;
motor[TRL] = 91;
motor[BLL] = 91;
motor[BRL] = -91;
wait1Msec (3000);
motor[TLL] = -91;
motor[TRL] = 91;
motor[BLL] = 91;
motor[BRL] = -91;
motor[Intake] = -125;
motor[Convey] = 125;
wait1Msec(12000);
task usercontrol()
// SensorValue[greenLED]=0;
// startTask(speedControl);
startTask(speedCalculate);
while (true)
//START INTAKE
if (vexRT[Btn5UXmtr2] == 1){// Intake All On
motor[Convey] = 125;}
if (vexRT[Btn7RXmtr2] == 1){// Intake All On
motor[Intake] = 125;
motor[Convey] = -125;}
if (vexRT[Btn5DXmtr2] == 1){// Intake Stop
motor[Intake] = 0;
motor[Convey] = 0;}
if (vexRT[Btn7UXmtr2] == 1){// Front Intake On
motor[Intake] = -125;}
if (vexRT[Btn7DXmtr2] == 1){// Back Intake On
if (vexRT[Btn7LXmtr2] == 1){// Back Intake Off
motor[Convey] = 0;}
if (vexRT[Btn7RXmtr2] == 1){// Front Intake Off
motor[Intake] = 0;}
//START FLYWHEEL, speeds in no particular order
if (vexRT[Btn8RXmtr2] == 1){// midcourt
target = 395;
lesser = 50;
higer = 125;
normal = 75;
motor[TLL] = -75;
motor[TRL] = 75;
motor[BLL] = 75;
motor[BRL] = -75;
else if (vexRT[Btn8DXmtr2] == 1){// BAR
target = 320;
lesser = 45;
higer = 125;
normal = 70;
motor[TLL] = -70;
motor[TRL] = 70;
motor[BLL] = 70;
motor[BRL] = -70;}
else if (vexRT[Btn8LXmtr2] == 1){// Midcourt 2
target = 360;
lesser = 50;
higer = 125;
normal = 73;
motor[TLL] = -73;
motor[TRL] = 73;
motor[BLL] = 73;
motor[BRL] = -73;}
else if (vexRT[Btn8UXmtr2] == 1){// Launcher Preset Speed TILE(FULL BATTERY) - no bang bang, didn't have enough time to tune accuracy
target = 450;
lesser = 90;
higer = 90;
normal = 90;
motor[TLL] = -90;
motor[TRL] = 90;
motor[BLL] = 90;
motor[BRL] = -90;}
else if (vexRT[Btn6UXmtr2] == 1){// Launcher Preset Speed TILE(Lower BATTERY)
target = 450;
lesser = 70;
higer = 125;
normal = 95;
motor[TLL] = -95;
motor[TRL] = 95;
motor[BLL] = 95;
motor[BRL] = -95;}
else if (vexRT[Btn8R] == 1){// Launcher Preset Speed TILE (Lower BATTERY)- no bang bang, didn't have enough time to tune accuracy
target = 450;
lesser = 85;
higer = 85;
normal = 85;
motor[TLL] = -85;
motor[TRL] = 85;
motor[BLL] = 85;
motor[BRL] = -85;}
else if (vexRT[Btn8L] == 1){// Launcher Preset Speed TILE(Lower BATTERY)- no bang bang, didn't have enough time to tune accuracy
target = 450;
lesser = 87;
higer = 87;
normal = 87;
motor[TLL] = -87;
motor[TRL] = 87;
motor[BLL] = 87;
motor[BRL] = -87;}
//Actual BANG BANG code, simplest form
else if (rpm > target) {
motor[TLL] = -lesser;
motor[TRL] = lesser;
motor[BLL] = lesser;
motor[BRL] = -lesser;
}else if (rpm == target) {
motor[TLL] = -normal;
motor[TRL] = normal;
motor[BLL] = normal;
motor[BRL] = -normal;
}else if (rpm < target) {
motor[TLL] = -higer;
motor[TRL] = higer;
motor[BLL] = higer;
motor[BRL] = -higer;
//START BASE PROGRAM - tank drive
motor[TR] = vexRT[Ch3] - vexRT[Ch1] - vexRT[Ch4];
motor[BR] = vexRT[Ch3] - vexRT[Ch1] + vexRT[Ch4];
motor[TL] = vexRT[Ch3] + vexRT[Ch1] + vexRT[Ch4];
motor[BL] = vexRT[Ch3] + vexRT[Ch1] - vexRT[Ch4];
task speedCalculate() //self explanatory, same speed calculate can be used in other velocity control loops - for future reference
while(true)
previousEncoder = SensorValue[wheelEncoder]; //Measure Encoder and time at beginning
previousTime = nSysTime;
wait1Msec(25); //Wait to measure changes
currentEncoder = SensorValue[wheelEncoder]; //Measure Encoder and time after delay
currentTime = nSysTime;
deltaEncoder = currentEncoder - previousEncoder; //Calculate changes
deltaTime = currentTime - previousTime;
rpm = (deltaEncoder*60)*(1000/deltaTime)/360; //calculate rpm but converrt degress to rotations, ms to s, s to minutes
wait1Msec(10); //Wait to allow calculations, as well as not hog CPU
