im wondering if you could help me finding solar panel with at least 18Volt
I found one solar panel but It has two usb output But i need solar panel with two outputs , one 18V Output for vex rover and one 5V usb power to Raspberry pi. Is there any solar panel that has what i need?
This link below is the solar panel i found but it has 2 usb output unfortunately
Vex motors are designed to run off 7.2V so 18V is too much for them.
You should scout around for teams that have unused 393 motors and use them for these solar projects. A gunk (good but not wanted) Cortex and kit will work fine. Putting at risk a $55 battery and a V5 brain seems a little wonky for a science fair project.
I would suggest, if you want to try solar power on a v5 system, that you go the route of making a solar powered battery charger for the v5 battery connected to the brain. We know that the v 5 battery can operate the brain while connected to the charger, so this will give you system stability. Investigate âthree terminal regulators,â and connect your solar cell to a voltage regulator circuit that matches the output of the V5 charger. Connect to the output of this circuit to the v5 battery, and you should have a system that will work without risk of damage to the V5 system.
A simple linear(3 wire) regulator will waste a lot of energy and get very hot as it will simply âcut offâ the excess voltage and turn it into heat. A buck converter would be better as it would lower the voltage to the required 16V for battery charging without losing much energy.
Edit: or a boost converter is the solar panel is <16V
Yes, a buck converter would be betterâŚlast time I had to build a little DC-DC converter for a job, those didnât exist (yes, Iâm pretty old, and I only dabble in controls a little bit), and the 3-terminal regulator was the best thing since sliced bread.
