Hey all, I have a quick question for you. Has anyone found a compiler that works with the Atom IDE environment? I’ve found a robotc language package so atom will detect what I’m doing, but the problem is that I’m doing all of my coding on a mac, so that removes any hope of using the actual robotc compiler to compile and check my work. Now if there is a way that I could supplement that with something that can at the very least test my code to see if it works I would be really grateful.
I’ma leave this here: https://pros.cs.purdue.edu
There is no way to do what you describe other than with the RobotC software on Windows. PROS, as suggested by @Ry1011, is cross-platform and would work, but you would need to switch to coding in PROS.
