So I can’t figure out what this error means:
Error:Task ‘scan’ is not defined at global scope level
Error:Tasks must be defined at main scope level
Could ya’ll help me out?
I’m using RobotC. Here’s the code:
#pragma config(Sensor, port12, sonar, sensorVexIQ_Distance)
#pragma config(Motor, motor1, scaner, tmotorVexIQ, PIDControl, encoder)
#pragma config(Motor, motor6, Ldrive, tmotorVexIQ, PIDControl, reversed, driveLeft, encoder)
#pragma config(Motor, motor7, Rdrive, tmotorVexIQ, PIDControl, driveRight, encoder)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task main()
task scan() {
while (true) {
setMotorTarget(scaner, 40, 10);
setMotorTarget(scaner, -40, 10);
repeat(forever)
startTask(scan);
if (getDistanceValue(sonar) <= 300)
stopAllMotors();
if (rand() % 2){
turnRight(random(350), degrees, 50);
else {
turnLeft(random(350), degrees, 50);
waitUntilMotorStop(Ldrive);
waitUntilMotorStop(Rdrive);
setMultipleMotors(100, Rdrive, Ldrive);
Your problem is that you are putting the task ‘scan’ in your ‘main’ task.
You have to define tasks and functions separately from your main task, like this:
task scan() {
while (true) {
task main() {
startTask(scan);
repeat(forever) {
if (getDistanceValue(sonar) <= 300) {
stopAllMotors();
if (rand() % 2) {
} else {
put this outside of the repeat loop
My bad, I edited it to make it correct.
@Uriah If the code didn’t work right before, it should now
