Need help with LemLib installation in VS code
Could anybody help with the error while running “pros c apply LemLib” in VS code. Thanks!
pros c apply LemLib
Updating LemLib… ERROR - main:main - HTTPSConnectionPool(host=‘raw.githubusercontent.com’, port=443): Max retries exceeded with url: /LemLib/LemLib/depot/stable.json (Caused by SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate
verify failed: unable to get local issuer certificate (_ssl.c:1129)’))) - pros-cli version:3.5.4
File “requests\sessions.py”, line 703, in send
File “requests\adapters.py”, line 698, in send
requests.exceptions.SSLError: HTTPSConnectionPool(host=‘raw.githubusercontent.com’, port=443): Max retries exceeded with url: /LemLib/LemLib/depot/stable.json (Caused by SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)’)))
Sentry is attempting to send 1 pending events
Waiting up to 2 seconds
Press Ctrl-Break to quit
I believe some repositories on github require sign-in.
Try signing in using git via
gh auth login
If this doesnt work, you may need to ensure you aren’t connected to school wifi if that is what you’re using.
Thanks! It indeed was an issue my computer somehow does not access to certain repository.
