I have a quick but rather important question. I am using this MOSFET http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=IRF530NPBF-NDfor an H-Bridge that will be controlled by a vex controller.
http://media.digikey.com/photos/International%20Rectifier%20Photos/TO-220AB.jpg
My question is, what are the pin assignments exactly? Which pin is the source, drain, and gate when looking at it from the front? I would really appreciate it if someone could help me because I do not want to solder the wrong pins.
Here is the datasheet for it if you want to look at it: http://www.irf.com/product-info/datasheets/data/irf530npbf.pdf
I really need to know this as soon as possible. Thanks as always.
