Need help with my bot
I have 4 motors 2 for each side of my bot and wont go forword the wheels get stuck or something if anyone has an answer please help
Sounds like one (or more) of your motors is reversed, you may need to switch the direction it spins in code
See if anything is touching the wheels. I saw that once with my bot
I tried but it didn’t work out so I was trying to find a differnt way but couldn’t figure it
could you send a picture? Also Amanda might be right.
A photo would be excellent. This could be any number of problems, we cant tell from that description.
Here’s a list of things you could check:
  1. CODE - if one of your motors is programmed to go the opposite way, then it could cause some issue
  2. CLEAN- if you have been using the drivetrain for a long time, maybe something got stuck in it
but maybe if you could post an image of your drivetrain, that could help!
