Need help with printing a png image onto V5 brain with SD card
I have tried using various code to print my logo onto my brain and none of it is working. Is it even possible yet?
What programming environment and language are you using?
I am using VCS and C++ pro
This was in december so they might support png but you may have better luck using bmp
VCS has never had an update, so supposedly this is still up to date.
That’s pretty much correct. We built the png image support into vexos, but you need an updated sdk for VCS to be able to easily take advantage of it. The png support in 1.0.5 also had a bug that was discovered after release that will be fixed in 1.0.6
