Need to display code on brain when on all the time
I need to display motor temps on the brain in Vexcode pro v5 but I can’t figure-out how to display this when it is on forever until turned off
Please send your current code, with code tags
[Code]Code goes here[/code]
I have the motor temp code on notes but I don’t know where to put it with the problem before, also I forgot to mention that I have 2 test motors and the brain because I don’t have the full bot with me.
/*    Module:       main.cpp                                                  */
/*    Author:       VEX                                                       */
/*    Created:      Thu Sep 26 2019                                           */
/*    Description:  Competition Template                                      */
// Robot Configuration:
// [Name]               [Type]        [Port(s)]
// Controller1          controller
// Controller2          controller
// Drivetrain           drivetrain    1, 2, 4, 5
// LeftArm              motor         20
// RightArm             motor         11
// Intake               motor         15
// Claw                 motor         3
// TempTest1            motor         6
// TempTest2            motor         7
#include "vex.h"
using namespace vex;
competition Competition;
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the V5 has been powered on and        */
/*  not every time that the robot is disabled.                               */
void pre_auton(void) {
  vexcodeInit();
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
void autonomous(void) {
  // Insert autonomous user code here.
Drivetrain.driveFor(forward, 12, inches);
Drivetrain.turnFor(left, 90, degrees);
Drivetrain.driveFor(forward, 18, inches);
Drivetrain.driveFor(forward, 4, inches);
Drivetrain.stop();
LeftArm.spinFor(reverse, 90, degrees);
RightArm.spinFor(forward, 90, degrees);
/*                              User Control Task                            */
/*  This task is used to control your robot during the user control phase of */
void usercontrol(void) {
  while (1) {
    //This is for the controll, make sure the Cotroller is added
    //Example //motor(PORT#).spin(vex::directionType::fwd,Controller1.Axis3.position(vex::percentUnits::pct),vex::percentUnits::pct);
   //This is Left Side AXES 3 and 4
    motor(PORT1).spin(vex::directionType::fwd,Controller1.Axis3.position(vex::percentUnits::pct),vex::percentUnits::pct);
    motor(PORT2).spin(vex::directionType::fwd,Controller1.Axis3.position(vex::percentUnits::pct),vex::percentUnits::pct);
    //This is Right Side AXES 1 and 2
    motor(PORT4).spin(vex::directionType::fwd,Controller1.Axis2.position(vex::percentUnits::pct),vex::percentUnits::pct);
    motor(PORT5).spin(vex::directionType::fwd,Controller1.Axis2.position(vex::percentUnits::pct),vex::percentUnits::pct);
    //Addition of Controller, Doing this you can have more then one motor to a single controller. Using name (buttons)
     if(Controller2.ButtonL1.pressing())
      motor(LeftArm).spin(vex::directionType::rev,70,vex::percentUnits::pct);
      motor(RightArm).spin(vex::directionType::rev,70,vex::percentUnits::pct);
    else if(Controller2.ButtonL2.pressing())
      motor(LeftArm).spin(vex::directionType::fwd,70,vex::percentUnits::pct);
      motor(RightArm).spin(vex::directionType::fwd,70,vex::percentUnits::pct);
    else
     motor(LeftArm).stop(vex::brakeType::hold);
      motor(RightArm).stop(vex::brakeType::hold);
    if(Controller2.ButtonUp.pressing())
      motor(Intake).spin(vex::directionType::fwd,85,vex::percentUnits::pct);
    else if(Controller2.ButtonDown.pressing())
      motor(Intake).spin(vex::directionType::rev,85,vex::percentUnits::pct);
    else
     motor(Intake).stop(vex::brakeType::hold);
if(Controller2.ButtonR1.pressing())
      motor(Claw).spin(vex::directionType::fwd,70,vex::percentUnits::pct);
    else if(Controller2.ButtonR2.pressing())
      motor(Claw).spin(vex::directionType::rev,70,vex::percentUnits::pct);
    else
     motor(Claw).stop(vex::brakeType::hold);
// Main will set up the competition functions and callbacks.
int main() {
  // Set up callbacks for autonomous and driver control periods.
  // Run the pre-autonomous function.
  pre_auton();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
The [code] needs to be on it’s own line
Formated Code
/ Module: main.cpp /
/ Author: VEX /
/ Created: Thu Sep 26 2019 /
/ Description: Competition Template /
// LeftArm motor 20
// Intake motor 15
// Claw motor 3
#include “vex.h”
/* Pre-Autonomous Functions /
/ You may want to perform some actions before the competition starts. /
/ Do them in the following function. You must return from this function /
/ or the autonomous and usercontrol tasks will not be started. This /
/ function is only called once after the V5 has been powered on and /
/ not every time that the robot is disabled. /
vexcodeInit();
// Example: clearing encoders, setting servo positions, …
/ Autonomous Task /
/ This task is used to control your robot during the autonomous phase of /
/ a VEX Competition. /
/ You must modify the code to add your own robot specific commands here. /
Drivetrain.stop();
/ User Control Task /
/ This task is used to control your robot during the user control phase of /
while (1) {
else
else
else
int main() {
pre_auton();
while (true) {
wait(100, msec);
I fixed the formatting issue and I added a detail to the message as well saying that I have 2 motors to test on because I don’t have my bot with me
I figured this out. At the beginning of driver control it prints the temps on the screen
    Brain.Screen.printAt(2, 40 ,"Claw Motor Temp %f " , Claw.temperature(percentUnits::pct));
    Brain.Screen.printAt(4, 60 ,"Intake Motor Temp %f " , Intake.temperature(percentUnits::pct));
    Brain.Screen.printAt(6, 80 ,"LeftArm Motor Temp %f " , LeftArm.temperature(percentUnits::pct));
    Brain.Screen.printAt(8, 100 ,"RightArm Motor Temp %f " , RightArm.temperature(percentUnits::pct));
    Brain.Screen.printAt(10, 120 ,"Motor Temp %f " , TempTest1.temperature(percentUnits::pct));
and so when on testing or on driver control as long the bot isn’t turned off it should give a reading
Without a while loop it will not update.
I believe it was in the driver control task while loop.
you are right
20char
