Toggled – A Flag status. A Flag is Toggled when the Flag’s pointer is not nested in the Detent
So is this flag toggled or not?
toggled red as the pointer is not seated at bottom of detent.
but i can be wrong.
The only way to know for sure is to ask in the official Q&A. Q&A: VRC 2018-2019: Turning Point : Robot Events
But, I agree with @lacsap that is would be toggled.
EDIT: I looked up the rule. I changed my mind. But it should still be asked.
I tried searching for this being discussed before but I couldn’t find anything. I wasn’t sure if I was just missing it or not.
I had the same question! Thanks for asking the forum.
Well, in speedcubing (which is solving Rubik’s cubes really fast), if the piece is turned more than 45 degrees towards the solved state, it counts as solved. I would apply the same methodology here, I think. It it’s not fully nested, it’s toggled. I’ll have to look fo the definition in the rule book to be sure.
EDIT: Looked up the rule. See my next post.
This quote of toggled from the manual does not specify fully nested, like I thought it might have. Therefore, I would call this flag not toggled. It has to be not nested in the detention, which I take to mean not nested at all.
I would still ask on the Q&A, though. Can somebody with the ability to do so do it?
I’m in the same boat, would have thought fully nested as that is easier for the referees to determine. However, it doesn’t appear that is the case. With a lot of play, the side of the detent can get worn down, and I can see this being more of a subjective call for the referees - which I don’t like.
There are five conditions, pointer on either side of the peak or resting on the peak of the detent red/blue and nested (valley of the detent). The picture looks like the third case - resting on the peak. Hence my original statement of Toggled RED.
If someone does not get to it sooner, I can post on the Q&A tonight with the conditions.
Thanks.
@lacsap It’s been taken care of. However, resting literally on top of the peak might be interesting. I don’t know if that would ever occur, and it depends on how they respond to the Q&A question. It wouldn’t be resting inside, nor outside of the detent.
I guess it would not be to the right or left of the detent, either. So I would apply the Same ruling the Q&A does, whenever they get around to it.
But resting on the slope outside of the detent should count as toggled, right?
For what it’s worth this picture was from a skills run. The team didn’t get credit for the point, but they will have additional chances in the future to get the flag scored more definitively.
Interesting. If it happened once, it’s bound to happen again. It would be nice to get a blanket ruling on this, just to be sure. But, I’m inclined to agree with the judge who scored their match.
Personally I have a difficult time describing this as nested. I do think this example is right at the dividing line, it’s at the point of the detent (worn though it may be), the flag detent indicator has no more room to rise. If it was any closer to being nested it would be considered nested. If it’s at this point or rotated farther then it would not be considered nested.
Until we get clarification I would probably rule that if the flag’s detent indicator is at or beyond the apex of the detent then it’s not nested. If the flag’s detent indicator has not yet reached the detent’s apex then it’s still nested.
As you are an EP, I respect your decision, but I won’t expect other EPs to follow you until we have a clarification. Thanks for your input.
If it was a cone from ITZ sitting on top of another cone like that(stretch analogy I know) it would NOT have been considered nested. Why would this be any different? Nested implies to me the point should be squarely in the valley.
We have always considered that the flag in the picture would be scored for red and not neutral.
I was thinking along the same terms, but they changed their definition of nested. It is further clarified by the section of the rule specifying that the flag would be to the left or right of the detent to be toggled for each team.
I would be satisfied either way, but how far would we go if we went so far as to say that it was toggled?
Where would we draw the line?
EDIT: Or did ITZ use the term nestled? I don’t remember.
Both used the term nested.
Huh, then we really need a clarification. The manual defines “scored,” but not “nested.” I’m still in the boat that it needs to be outside of the detent to be toggled. But, I would like it to count as toggled, just I think that it won’t be.
