I’ve seen a lot of this going on lately (over the christmas holidays) while people have noone to have practice matches against. Takes a LOT more skill than it looks like O_O
If The Record is ten points then they have been beaten, i saw a team full that center goal full then squish the stack so nobody else can score and then put another barrel somehow and finally added the doubler for a total of about 18 points on the center goal. This Team Was Quick. I Think it was a 254 team but im not sure. Im also not sure if it got on picture or camera but yeahhh so
Sorry, yes. I meant ten objects. We don’t go by points because we use it to see how many we can stack precariously on the top. so the doubler is just a normal barrel to us.
this was actually REAL!
it took like 30 mins just to get it right!
even though 5 is a lousy score, we “capped” it twice
which kinda defeats the term “cap”
By “score” do you mean objects scored or points scored? because of course I’d have to see actual goal to properly comment but from what I can guess there’s only 3 objects scored, for 4 points Like I said though, a different view might tell a different story…
Actually, I don’t think it’s occurred to us before that any object that’s below the plane of the goal has to be within the outer ring of the goal too. We’ll have to try it out and see how that turns out, because then it’s not scored and can be removed. Of course, do you really want to take that chance by descoring it?
I’m pretty sure from playing around we did that at least one of that bottom set has to be partially outside the outer ring of the goal, and from the angle shown it looks like possibly the both of them are partially outside so they wouldn’t be scored. Like I said though, without having a whole bunch of different angles it’s hard to tell
Technically it’s already descored because it’s not counting for anything, so if that object was at one point scored by Clause 1 (below the top AND fully within the outer ring) and you pushed it down further such that it it was no longer scored, you should technically be DQed… Just pointing that out
