LDEP(Low Density Polyethylene) this material is flexible i was able to make a cylinder hot dog style or from the 12" length it does have resistance sliding on top the foam tile. thats all we experimented with this material
polypropylene is a more ridgid material still has some flexablility but i would say its more rigid then poly-carbonate we found that this material slides beautify against another sheet of polypropylene. it has little resistance against the foam tile.
that was done with 1/16 inch thick sheets 12X24
if there is anything else you would like me to test then ask me and ill try do it.
P.S i will not test the breaking point of them XP
Comment what other type of plastic you have and its properties.
i honestly thought LDPE was just a ligher weight was then poly carbonate but it ended up being a flexable sheet.
