As announced at the 2011 VEX Robotics World Championship, VEX Robotics, Inc. is pleased to provide information on several new products that are now available for purchase.
Turntable Bearing Kit - P/N: 276-1810 - $19.99
http://www.vexrobotics.com/products/accessories/motion/276-1810.html
The VEX Turntable Bearing Kit provides two options for low friction, high load rotational joints. These are especially well suited for rotational joints with lots of side load - this kit makes it easy to build a turret on your robot! Integrated gearing makes each turntable simple to actuate while other features allow for a variety of design uses.
2.75" Omni Directional Wheel - Double Roller (2-pack) - P/N: 276-1902 - $19.99
http://www.vexrobotics.com/products/accessories/motion/276-1902.html
A double-roller omni-directional wheel in a new size! Use these wheels to make your robot turn smoothly or build a holonomic drivetrain.
Yaw Rate Gyroscope Sensor V1.0 - P/N: 276-2333 - $39.99
http://www.vexrobotics.com/products/accessories/sensors/276-2333.html
Use a gyro to enhance autonomous movement and feedback from a VEX robot.
VEXnet Joystick Power Adapter - P/N: 276-1701 - $12.99
http://www.vexrobotics.com/products/accessories/power/276-1701.html
Extend your runtime by powering your VEXnet Joysitck directly from a wall outlet. Simply connect this adapter to the VEXnet Joystick’s programming port and you’re good to go for hours and hours.
Additionally, the **VEX Gateway Goal & Object Kit is now available in limited quantities for $49.99.
Full stock on this kit as well as the full VEX Gateway Field & Game Object Kit will be available in June.**
