Hi guys!
I am very new to the form and competition, and I am checking on the process to registrate a new team.
However, I can’t find the invoice from the robotevent.com. Can any expert here help me out?
Thank you in advanced!
here is the real link and i can help you out https://www.robotevents.com/
https://www.robotevents.com/robot-competitions/vex-robotics-competition?country_id=244&seasonId=&eventType=&eventTag=&name=&grade_level_id=&level_class_id=&from_date=05%2F12%2F2022&to_date=&event_region=&city=&affiliation_id=
here u go it has everything you might need
@Weiming_Tie
Thank you so much for the links. My principals are looking for a invoice so they can create the Purchase Order for the team registration. But, I can’t find the location for the invoice on the website. Do you mind to share a little insight on this mater?
Thank you again!
here i got one for you its all you will need for 1 team
https://docs.google.com/spreadsheets/d/1v9KzruahP4KkY4z7CwzyntUOfRJLoPw35xWzGdvdvIM/edit?usp=sharing
@Weiming_Tie
sorry i thought you meant for parts i haven’t ever used the invoice for the team registration
l0l That was awsome!!!
Thank you!!!
Welcome to the forums. Just a reminder, when creating topics, make sure to properly catagorize them.
Thank you for the reminder! Will do!
So I see you have a very helpful list there totaling 7K without stuff like registration. Do you suggest for a new team to get everything on there? And what would be the pro/con of replacing some of the basic elements on there by buying a competition super kit, the backorder situation aside?
i just have it as a reference for new users and yes there is some cons but once you use Purdue sigbots guide it helps out find and fix the problems with the chance of them breaking if not used right
The coach/team contact needs to create an account on RobotEvents. That can be done here:
https://www.robotevents.com/auth/register
If you are a student on the team, then you need whoever will be your adult contact/coach do it. If you are the adult, then you can do it.
The email used to create the account will need to be verified in order to register a team. Once an account is created and the email is verified, choose the program from the Robot Competitions dropdown on the top left. On the program page, choose “Register a Team”. Go through the registration process for the team and when you get to the checkout steps there will be an option to generate a quote instead of completing the payment. Your principal will be able to create a PO based on the quote. Once you have the PO, you can go back into the order and complete it by entering the PO number and uploading the PO.
Thank you so much for eveyone’s participation to this basic level topic! I did manage to get the invoice to the pricipals, and I am looking for the materals now! Thank you again, and have a wonderful weekend!!
@Weiming_Tie what competition are you doing vrc or IQ
Hi, welcome to the forum!
With running a new team, we recommend these resources:
This wiki has many resources on hardware, software, as well as how to start a new team:
Please check us out!
Hi, I am new to coding and I can’t figure out how to do something on vex code v5 pro.
how do you do: if button A pressed run scissor_lift motor forward for 10 seconds?
If you are new to coding, I recommend using VexCode V5 Blocks to get the hang of coding before immediately rushing to Pro.
Assuming you already have blocks, you can use the convert feature to learn how block code looks in text. Good luck!
I figured it out, I did: if (Controller1.ButtonA.pressing()) {
scissor_lift.spinFor(reverse, 1.5,seconds);
