No Reply Option Available
I’ve found a lot of threads I cannot respond to and they’re not in official forums. The problem I seem to be having is that if I click on the log-in in the reply window that thread becomes eternally blocked, never again showing a reply block at the bottom. But if I’m already logged in, then I can go to any thread I haven’t visited and reply. I’ve tried reloading the pages, restarting the browser and the computer, logging back out and in. I can’t find a fix. Has anyone seen this behavior? Anyone have a solution?
Thanks
Can you give examples? Do you have any links or thread names?
Its because they are official Q&A so only officials can
He says they are not official forums, so just gotta be sure ¯_(ツ)_/¯
Pssshhhhh i can totally read
I think I spotted some of the problems. The RobotC forum is not “official” but actually is, right? (Others are labeled “official” when they’re official; I don’t see why this shouldn’t be as well for clarity.) Another was in the general forum, but the original post has been deleted. Now that it’s deleted I can reply. I wonder if maybe it was being edited/deleted as I was trying to reply. Maybe the seeming pattern was just an odd combination of timings. I need to try to remember if there was a third or not.
This was the first place it showed up, where I said it now works. It acted just like an official forum:
https://vexforum.com/index.php/27481-isolated-code-works-fails-when-integrated
The forum channels will show a popup with more info, for example, on the RobotC forum.
Yes, I discovered that more recently. I hadn’t hovered over it for long enough before, but I figured it out later.
But the general forum doesn’t register as official. And that’s where I first encountered the issue. I suspect it has something to do with an original post being edited blocking replies or something like that.
Thanks.
@callen
This is the first time I’m hearing of this issue. If you happen to run across it again, please post a link to the thread here, or send me a PM.
I am having trouble writing a reply in the beta test forums. it either does not show up with the box to reply in or it comes up and says I do not have permission to post here. Any ideas?
@andersonmatt
All channels other than General Discussion can only be answered by official VEX Staff. Start a new thread in one of the official beta channels to get any of your questions answered.
