@jpearman
hello all, today im having an extremely peculiar situation, whenever i click start, the wheels run full forward forever, however whenever i click “step intro” it goes backwards lick its supposed to, whenever i click start, it follows a preversion of logic, meaning that whenever it should enter the sensorvalue<targetvalue, (sensor is target) it enters the line of code that says sensorvalue>targetvalue please help, i dont understand
#pragma config(Sensor, in1, lift, sensorPotentiometer)
#pragma config(Sensor, in2, clawS, sensorPotentiometer)
#pragma config(Sensor, dgtl1, LDsensor, sensorQuadEncoder)
#pragma config(Sensor, dgtl3, RDsensor, sensorQuadEncoder)
#pragma config(Sensor, dgtl5, topreset, sensorTouch)
#pragma config(Sensor, dgtl6, bottomreset, sensorTouch)
#pragma config(Motor, port1, CR, tmotorVex393HighSpeed_HBridge, openLoop)
#pragma config(Motor, port2, LD, tmotorVex393_MC29, openLoop, encoderPort, dgtl1)
#pragma config(Motor, port3, LTM, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port4, LMM, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port5, LBM, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port6, RTM, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port7, RMM, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, RBM, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port9, RD, tmotorVex393_MC29, openLoop, encoderPort, dgtl3)
#pragma config(Motor, port10, CL, tmotorVex393_HBridge, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
//sensor not in sensorValue is what you want it to go to
void hang (float sensor)
motor[LD]=127;
motor[RD]=127;//drive forward
while(SensorValue[lift]<sensor)
motor[LTM]=127;
motor[LMM]=127;
motor[LBM]=127;
motor[RTM]=127;
motor[RMM]=127;
motor[RMM]=127;// pull up
while(SensorValue[lift]>sensor)
motor[LTM]=0;
motor[LMM]=0;
motor[LBM]=0;
motor[RTM]=0;
motor[RMM]=0;
motor[RMM]=0;
wait1Msec(100);
void turnR (float speed, float Lsensor, float Rsensor)
while(SensorValue[LDsensor]<.8*Lsensor& SensorValue[RDsensor]<.8*Rsensor)
motor[LD]=-speed;
motor[RD]=speed;
while(SensorValue[LDsensor]>(.8*Lsensor+.8*Rsensor)*.5 & SensorValue[LDsensor]<Lsensor &SensorValue[RDsensor]<Rsensor)
motor[RD]=1/2*-speed;
motor[LD]=1/2*speed;
void driveF (float speed, float sensor)
wait10Msec(10)
if(sensorvalue[ldsensor]>sensor)
motor[LD]=-speed;
motor[RD]=-speed;
waitUntil(sensorvalue[LDsensor+RDsensor]>1.75*sensor)
motor[LD]=3/4*-speed;
motor[RD]=3/4*-speed;
waitUntil(SensorValue[LDsensor+RDsensor]>2*sensor)
motor[ld]=0
motor[RD]=0
else if(sensorvalue[LDsensor]<sensor)
motor[LD]=speed;
motor[RD]=speed;
waitUntil(sensorvalue[LDsensor]>1.75*sensor);
motor[LD]=3/4*speed;
motor[RD]=3/4*speed;
waitUntil(SensorValue[LDsensor]>sensor);
motor[ld]=0;
motor[rd]=0;
else if(sensorvalue[ldsensor]>sensor)
motor[LD]=-speed;
motor[RD]=-speed;
motor[ld]=0
motor[RD]=0
void liftup (float sensor)
motor[LTM]=-127;
motor[LMM]=-127;
motor[LBM]=-127;
motor[RTM]=-127;
motor[RMM]=-127;
motor[RMM]=-127;
motor[LTM]=0;
motor[LMM]=0;
motor[LBM]=0;
motor[RTM]=0;
motor[RMM]=0;
motor[RMM]=0;
void liftdown (float sensor)
motor[LTM]=127;
motor[LMM]=127;
motor[LBM]=127;
motor[RTM]=127;
motor[RMM]=127;
motor[RMM]=127;
motor[LTM]=0;
motor[LMM]=0;
motor[LBM]=0;
motor[RTM]=0;
motor[RMM]=0;
motor[RMM]=0;
void claw(float sensor)
if(sensor>SensorValue[clawS])
motor[CR]=127;
motor[CL]=127;
while(SensorValue[clawS]>sensor)
motor[CR]=0;
motor[CL]=0;
wait1Msec(0);
void turnL(float speed, float sensorR, float sensorl)
motor[LD]=speed;
motor[RD]=-speed;
waitUntil(SensorValue[LDsensor]>sensorl & SensorValue[LDsensor]>sensorR);
motor[RD]=0;
motor[LD]=0;
task main()
while(1==1)
driveF(60, -320);
claw(1000);
driveF(127, -320);
claw(2300);//pick up first driver load cube
drivef(-127, -885)
liftup(247); // lift up to dump cub #1
claw(1000);// dump cube #1
liftdown(247);
driveF(127,-320); // drive forwards to grab another cube
claw(2300);// pickup cube
drivef(-127, -885)
liftup(247);
claw(1000); // dump cube #2
liftdown(247);
drivef(127, -320);
claw(2300);//grab 3 driver load stars
drivef(127, -885)
liftup(247);
claw(1000);// dump 3 stars
liftdown(247);
turnR(127, -1070, -700);// turn to grab 3 fence stars
SensorValue[RDsensor]==0;
SensorValue[LDsensor]==0;
drivef(127, 1500);
claw(2300);//grab 3 stars
turnl(127, 1692, 1290)
liftup(247);//lift to dump 3 fence stars
claw(1000);
liftdown(247)
turnR(80, -1069, -704);
claw(1000);//dump 3 stars
liftdown(247);
driveF(80, -160);// grab middle cube
claw(2300);//grab middle cube
liftup(247);
drivef(80, 400);
claw(1000);// dump middle cube
liftdown(247);//reset arms
turnL(127, 38, -181);// aim at back cube
driveF(100, 420);
claw(2300);//grab back cube
liftup(247);
turnr(127, 332, 501);//aim at right fence
driveF(-100, -260);
claw(1000);//dump back cube
driveF(80, -330);//drive to middle of the feild
turnL(127, 917, 869);//aim at hang pole
driveF(-80, 000);//drive into pole
liftup(247);
liftdown(247);
