Nothing works when I connect my controller
I posted about this a couple of days ago and have now found the underlying problem but have no idea how to fix it. If the controller is not on, I can test the motors using the devices button on the brain and everything works smoothly. The problem is that once I turn the controller on, I can’t even test the motors directly from the brain. I have tried multiple different controllers and brains and have had no luck at all. I have a competition tommorrow so I’m really panicking right now
By “controller on” do you mean you turned the program on? You can’t move motors with the devices menu while a program is running, you have to turn off the program to do that. While a program is running, only the program itself can control motors
