Vex Coding Studio doesn’t seem to be the ideal coding studio at the moment. Sure, it’s a brand new thing, and it’s going to have it’s flaws, but another IDE wil usually just be better. But, what if you want to use the official API still?
NotVCS is a python script that can extract and repack .vex files. Thats about all I have to say here. If you are interested in using it, it is available for free on this github repo.
This software is still in it’s early stages and will almost certainly be riddled with bugs. Please make backups of your vex files before using.
I love it =).
Useful for people who need version control or another IDE, but are somehow required to use VCS.
Too bad it does not allow you to create multiple files within the .vex file, I guess VCS can only handle robot-config.h and main.cpp. It would be cool if it could repack automatically on file change and notify VCS to reload the file, though I would be surprised if that was possible.
Nice work.
A new beta update for NotVCS, now VCS4CMD, has been released.
I’ve been busy researching ways to compile and upload .cpp files from the command line without abandoning the official API. While, in it’s current state, this requires both PROS and Vex Coding Studio to be installed, and this (https://gist.github.com/Dysproh/c3773484fc15794aa140475799a4d705) makefile to be in your Vex Coding Studio\sdk\user folder, it still has all of the features of the old NotVCS, which is also still available for download on my git repo. There is a possibility of not needing PROS to upload code to the robot at some point, but for now, that is the only way.
Also, auto-open from the previous update now works on OSX.
Judging by the dependency on pros I think @DrewWHOOP still uses prosv5 make and prosv5 upload so the VS code extension would still work. Either that or be trivial to modify.
The Cli nature of PROS makes plug-ins for IDEs trivial
Hi, I’m getting an error when I attempt to unpack my program, I’m wondering if I’m doing something wrong. I navigate to my directory that my program and VCSCMD.py are in, then call
python VCSCMD.py -u --file "Program 1".vex
and receive the error
Reading from file Program 1.vex
Traceback (most recent call last):
File "VCSCMD.py", line 121, in <module>
with open('unpacked/vexfile_info.json', 'w', newline='') as csvFile:
TypeError: 'newline' is an invalid keyword argument for this function
I’m not sure whats going on there, though my guess would be that you might be using Python 2.x, while VCS4CMD requires Python 3.x.
Run python -V to check python version.
As for @tabor473 VCS4CMD uses PROS upload for now, since I haven’t figured out how to upload directly. For now, I recommend using the -po option rather than -l, since it doesn’t require PROS, and, while it isn’t as automatic, it is far less buggy, since I haven’t ironed out all of the bugs with command-line make and upload. However, it still uses VCS make and the VCS api when using -l.
I hope bringing this thread back doesn’t count as necroposting, because a new update is out!
Also, don’t use VCS4CMD.py; its bad and I should probably delete it
What does this update bring? NotVCS Extensions!
What is a NotVCS Extension? A NotVCS Extension (*.nvcx) is basically a glorified library. Basically, you can now install these extensions with nvcspacker.py to be able to #include your code. This isn’t actually documented in the readme.md, but I think the --help for this file explains enough.
Also, a recent update that I didn’t feel warranted reviving this thread added support for main.cc in addition to main.cpp as your main file.
