Object Isnt Subsriptable?
Im currently working on a project where the claw bot I have built finds and places a yellow cone onto a red mobile base.
My current code is as followed;
#region VEXcode Generated Robot Configuration
from vex import *
import urandom
# Brain should be defined by default
brain=Brain()
# Robot configuration code
left_drive_smart = Motor(Ports.PORT10, GearSetting.RATIO_18_1, False)
right_drive_smart = Motor(Ports.PORT1, GearSetting.RATIO_18_1, True)
drivetrain = DriveTrain(left_drive_smart, right_drive_smart, 319.19, 295, 40, MM, 1)
Arm = Motor(Ports.PORT8, GearSetting.RATIO_18_1, False)
Claw = Motor(Ports.PORT4, GearSetting.RATIO_18_1, False)
controller_1 = Controller(PRIMARY)
optical_11 = Optical(Ports.PORT11)
# vex-vision-config:begin
vision_5__RED_CONE = Signature(1, 8061, 8981, 8521,-1137, -677, -907,2.5, 0)
vision_5__YELLOW_CONE = Signature(2, 2163, 3641, 2902,-4369, -3627, -3998,2.5, 0)
vision_5 = Vision(Ports.PORT5, 50, vision_5__RED_CONE, vision_5__YELLOW_CONE)
# vex-vision-config:end
distance_2 = Distance(Ports.PORT2)
# wait for rotation sensor to fully initialize
wait(30, MSEC)
def play_vexcode_sound(sound_name):
    # Helper to make playing sounds from the V5 in VEXcode easier and
    # keeps the code cleaner by making it clear what is happening.
    print("VEXPlaySound:" + sound_name)
    wait(5, MSEC)
# add a small delay to make sure we don't print in the middle of the REPL header
wait(200, MSEC)
# clear the console to make sure we don't have the REPL in the console
print("\033[2J")
# define variables used for controlling motors based on controller inputs
controller_1_left_shoulder_control_motors_stopped = True
controller_1_right_shoulder_control_motors_stopped = True
drivetrain_l_needs_to_be_stopped_controller_1 = False
drivetrain_r_needs_to_be_stopped_controller_1 = False
# define a task that will handle monitoring inputs from controller_1
def rc_auto_loop_function_controller_1():
    global drivetrain_l_needs_to_be_stopped_controller_1, drivetrain_r_needs_to_be_stopped_controller_1, controller_1_left_shoulder_control_motors_stopped, controller_1_right_shoulder_control_motors_stopped, remote_control_code_enabled
    # process the controller input every 20 milliseconds
    # update the motors based on the input values
    while True:
        if remote_control_code_enabled:
            # calculate the drivetrain motor velocities from the controller joystick axies
            # left = axis3
            # right = axis2
            drivetrain_left_side_speed = controller_1.axis3.position()
            drivetrain_right_side_speed = controller_1.axis2.position()
            # check if the value is inside of the deadband range
            if drivetrain_left_side_speed < 5 and drivetrain_left_side_speed > -5:
                # check if the left motor has already been stopped
                if drivetrain_l_needs_to_be_stopped_controller_1:
                    # stop the left drive motor
                    left_drive_smart.stop()
                    # tell the code that the left motor has been stopped
            else:
                # reset the toggle so that the deadband code knows to stop the left motor next
                # time the input is in the deadband range
                drivetrain_l_needs_to_be_stopped_controller_1 = True
            if drivetrain_right_side_speed < 5 and drivetrain_right_side_speed > -5:
                # check if the right motor has already been stopped
                if drivetrain_r_needs_to_be_stopped_controller_1:
                    # stop the right drive motor
                    right_drive_smart.stop()
                    # tell the code that the right motor has been stopped
            else:
                # reset the toggle so that the deadband code knows to stop the right motor next
                drivetrain_r_needs_to_be_stopped_controller_1 = True
            # only tell the left drive motor to spin if the values are not in the deadband range
                left_drive_smart.set_velocity(drivetrain_left_side_speed, PERCENT)
                left_drive_smart.spin(FORWARD)
            # only tell the right drive motor to spin if the values are not in the deadband range
                right_drive_smart.set_velocity(drivetrain_right_side_speed, PERCENT)
                right_drive_smart.spin(FORWARD)
            # check the buttonL1/buttonL2 status
            # to control Arm
            if controller_1.buttonL1.pressing():
                Arm.spin(FORWARD)
                controller_1_left_shoulder_control_motors_stopped = False
            elif controller_1.buttonL2.pressing():
                Arm.spin(REVERSE)
            elif not controller_1_left_shoulder_control_motors_stopped:
                Arm.stop()
                # set the toggle so that we don't constantly tell the motor to stop when
                # the buttons are released
            # check the buttonR1/buttonR2 status
            # to control Claw
            if controller_1.buttonR1.pressing():
                Claw.spin(FORWARD)
                controller_1_right_shoulder_control_motors_stopped = False
            elif controller_1.buttonR2.pressing():
                Claw.spin(REVERSE)
            elif not controller_1_right_shoulder_control_motors_stopped:
                Claw.stop()
        # wait before repeating the process
        wait(20, MSEC)
# define variable for remote controller enable/disable
remote_control_code_enabled = True
rc_auto_loop_thread_controller_1 = Thread(rc_auto_loop_function_controller_1)
#endregion VEXcode Generated Robot Configuration
vexcode_vision_5_objects = None
vexcode_vision_5_object_index = 0
message1 = Event()
myVariable = 0
opem = 0
close = 0
grabbed = 0
cone_in_air = 0
def Find_Base():
    global message1, myVariable, opem, close, grabbed, cone_in_air, vexcode_vision_5_objects, vexcode_vision_5_object_index
    while True:
        vexcode_vision_5_objects = vision_5.take_snapshot(vision_5__RED_CONE)
        if vexcode_vision_5_objects and len(vexcode_vision_5_objects) > 0:
            drivetrain.turn_for(RIGHT, 20, DEGREES)
            wait(1, SECONDS)
            break
        else:
            drivetrain.turn_for(RIGHT, 4, DEGREES)
        wait(5, MSEC)
    while True:
        if vexcode_vision_5_objects[vexcode_vision_5_object_index].centerX < 95 and vexcode_vision_5_objects and len(vexcode_vision_5_objects) > 0:
            wait(0.25, SECONDS)
            drivetrain.turn_for(LEFT, 7, DEGREES)
            wait(0.25, SECONDS)
            drivetrain.drive_for(FORWARD, 100, MM)
        if vexcode_vision_5_objects[vexcode_vision_5_object_index].centerX > 100 and vexcode_vision_5_objects and len(vexcode_vision_5_objects) > 0:
            wait(0.25, SECONDS)
            drivetrain.turn_for(RIGHT, 7, DEGREES)
            wait(0.25, SECONDS)
        if distance_2.object_distance(MM) < 270:
            wait(0.25, SECONDS)
            break
        wait(5, MSEC)
def Drop():
    wait(0.25, SECONDS)
    Arm.spin_to_position(500, DEGREES)
    wait(0.25, SECONDS)
    drivetrain.drive_for(FORWARD, 300, MM)
    wait(0.25, SECONDS)
    Claw.spin_for(REVERSE, 360, DEGREES)
    wait(0.25, SECONDS)
    drivetrain.drive_for(REVERSE, 300, MM)
    wait(0.25, SECONDS)
    Arm.spin_to_position(0, DEGREES)
    wait(0.25, SECONDS)
    drivetrain.turn_for(RIGHT, 90, DEGREES)
    wait(0.25, SECONDS)
    Claw.spin_to_position(0, DEGREES)
def Start():
    Arm.spin_for(FORWARD, 45, DEGREES)
    close = 0
    opem = 0
    grabbed = 0
    cone_in_air = 0
    drivetrain.set_turn_velocity(30, PERCENT)
    drivetrain.set_drive_velocity(25, PERCENT)
    Arm.set_velocity(25, PERCENT)
    Claw.set_stopping(HOLD)
    Arm.set_stopping(HOLD)
    while True:
        vexcode_vision_5_objects = vision_5.take_snapshot(vision_5__YELLOW_CONE)
            wait(0.25, SECONDS)
            drivetrain.turn_for(RIGHT, 25, DEGREES)
            wait(0.25, SECONDS)
            break
        else:
            wait(0.25, SECONDS)
        wait(5, MSEC)
    while True:
            wait(0.25, SECONDS)
            wait(0.25, SECONDS)
            wait(0.25, SECONDS)
            wait(0.25, SECONDS)
        if distance_2.object_distance(MM) < 200:
            break
        wait(5, MSEC)
def pick_up():
    while True:
        if distance_2.object_distance(MM) < 175 and distance_2.object_distance(MM) > 160:
            wait(0.25, SECONDS)
            Claw.spin_for(FORWARD, 152, DEGREES)
            wait(0.25, SECONDS)
            grabbed = grabbed + 1
        if not (distance_2.object_distance(MM) < 175 and distance_2.object_distance(MM) > 160):
            wait(0.25, SECONDS)
            drivetrain.drive_for(FORWARD, 200, MM)
        if grabbed == 1:
            wait(0.25, SECONDS)
            Arm.spin_for(FORWARD, 150, DEGREES)
            wait(0.25, SECONDS)
            cone_in_air = cone_in_air + 1
            wait(0.25, SECONDS)
            break
        wait(5, MSEC)
def when_started1():
    Start()
    pick_up()
    Find_Base()
    Drop()
when_started1()
What is the question?
