Object tracking vision sensor
Hey i am building a robot and i waant it to follow an object. I am using v5 blocks because my teacher said he couldent get the other ones to work. would really appreciate some help.
As this is not concerning the website itself, please change the topic of this thread to VexCode V5 blocks instead.
If you go into blocks click file and select open examples then at the top select sensing you will find a example code you can use to incorporate it to your normal code.
