odd robot response
At a recent tournament my team’s robot got stuck running autonomous during the tie breaker of the finals in elimination. As the match started, autonomous began to run. part way through, something happened to the robot causing it to become unresponsive and leaving all motors in their last state. for the rest of the match the robot was stuck with all the motors driving in some direction and didn’t change to usercontrol.
Officials told us that this was caused by an infinite loop in the autonomous code which caused the robot to freeze. The inifinite loop was said to be caused by a sack being caught in a wheel stopping it from reaching its intended point. I don’t believe this is the case. the wheels of the robot were not near any sacks when it became unresponsive. furthermore, the arm of the robot shouldn’t have been affected by drive wheels getting stuck because it is run in a completely different task. within this task, there are safeties running to prevent the motors from driving past a certain region as it did. this makes me believe something witht he game controller caused my robot to become unresponsive because my program can’t cause the arm to become unresponsive. has anyone else experienced this? what could have caused this?
Did you see these comments?
https://vexforum.com/t/re-game-controller-issues/23176/1
i was running an autonomous program using the vexnet competition controller on a practice field at an event , and it was running it using while loops, and basically the vexnet disconnected for some reason making it run the drive and lift motors at 127; (motors in last state) … and basically i ran onto the field and turned it off before it broke something, my opponents were annoyed but i think it is because disconnection of vexnet … it hasn’t happened since, but i have replaced my vexnet keys since then …
if you find an answer, pass it onto me please :wink:
Do you have integrated motor encoders on your robot?
thank you jpearman, i didn’t see that link but i’ll subscribe to it and reply
team 5119, i will try to keep you posted. if it was a cutout then the robot would have killed the motors and go into searching for the vexnet connection indicated by the flashing vexnet light.
fretless_kb, i am using the integrated encoders and they are fully functional. they were seeing real numbers at the time my robot died.
