Hey, I am just writing my own odometry and I am just stuck on covertion my local variables to global.
My code look like this for now-
// encoders values
int L_ENC_value = 0.0;
int M_ENC_value = 0.0;
// change in encoders
int lDelta = 0.0;
int mDelta = 0.0;
// previous encoders values
int last_lDelta = 0.0;
int last_mDelta = 0.0;
// distance in inches
float lDist = 0.0;
float mDist = 0.0;
// The current angle of the bot (RADIANS)
float currentAbsoluteOrientation = 0;
// The previous angle of the bot (RADIANS)
float last_Theta = 0;
// change in the angle(RADIANS)
float deltaTheta = 0;
// average theta for the arc
float avgThetaForArc = 0;
// local position
float x_pos_local = 0;
float y_pos_local = 0;
// the global postion in arc
float delta_x_pos_global = 0;
float delta_y_pos_global = 0;
// global position of the robot
float x_pos_global = 0;
float y_pos_global = 0;
// total local position
float t_x_pos_local = 0;
float t_y_pos_local = 0;
int odomtrack()
while (true)
// getting values from encoders
L_ENC_value = L_Encoder.get_value();
M_ENC_value = M_Encoder.get_value();
// get the change of the values
lDelta = L_ENC_value - last_lDelta;
mDelta = M_ENC_value - last_mDelta;
// trasform values to inches
lDist = lDelta / degrees_side_per_inch;
mDist = mDelta / degrees_side_per_inch;
// calculate the current angle of the robot in radians
currentAbsoluteOrientation = (int)inertial.get_rotation() * drive_pi / 180;
// get change in the angle
deltaTheta = currentAbsoluteOrientation - last_Theta;
// transform my current values to previous values
last_lDelta = L_ENC_value;
last_mDelta = M_ENC_value;
last_Theta = currentAbsoluteOrientation;
// if there is no angle change, then it is only change in encoders
if (deltaTheta == 0)
y_pos_local = lDist;
x_pos_local = mDist;
// calculate the x-position and y-position
else
y_pos_local = (lDist / deltaTheta + dRobotSide) * (2 * sinf(deltaTheta / 2.0));
x_pos_local = (mDist / deltaTheta + dRobotMiddle) * (2 * sinf(deltaTheta / 2.0));
t_x_pos_local += x_pos_local;
t_y_pos_local += y_pos_local;
// printing the values
lcd::print(4, "pl:%d, pm:%d, pt:%d", last_lDelta, last_mDelta, deltaTheta);//left encoder delta, middle encoder delta, theate delte(radians)
lcd::print(5, "ty:%f,tx:%f",t_y_pos_local, t_x_pos_local);// total y local, total, x local
lcd::print(6, "lenc:%d, menc:%d",L_ENC_value, M_ENC_value);// values from left encoder, values from middle encoder
delay(20);
return 1;
Any tips or help are welcome
