Okapi chassis won't change speed
When coding my autons using okapi chassis builder. I couldn’t get the chassis to change speed when using. chassis->getModel()->setMaxVelocity(100); I’m using okapi V4 and pros V3.2.0.
Motor leftMotor(7, false, AbstractMotor::gearset::red, AbstractMotor::encoderUnits::degrees);
Motor rightMotor(5, true, AbstractMotor::gearset::red, AbstractMotor::encoderUnits::degrees);
Motor middleMotor(6, false, AbstractMotor::gearset::red, AbstractMotor::encoderUnits::degrees);
std::shared_ptr<ChassisController> chassis = ChassisControllerBuilder()
  .withMotors(leftMotor, rightMotor, middleMotor)
  .withSensors(leftEncoder, rightEncoder)
  .withDimensions(AbstractMotor::gearset::red, {{4_in, 10_in}, imev5RedTPR})
  .withMaxVelocity(60)
  .withLogger(
      std::make_shared<Logger>(
          TimeUtilFactory::createDefault().getTimer(), // It needs a Timer
          "/usd/Chassis_Diagnostics", // Output to the SDCard
          Logger::LogLevel::info // Most verbose log level
  .build();
void autonomous() {
  chassis->moveDistance(1_ft);
Please upgrade to v4.0.1 and use this method instead okapi::ChassisController class | OkapiLib A PROS library for programming VEX robots
