When I run my code the operator control runs fine. However, in the autonomous the robot drives forward and then the left side stops when it is supposed to but the right keeps going forever. I even tried adding a stop afterwards. Here’s my code. Do you guys know what the issue is?
#include "main.h"
using namespace okapi;
Motor frontLeftMotor(1, false, AbstractMotor::gearset::green, AbstractMotor::encoderUnits::degrees);
Motor frontRightMotor(2, true, AbstractMotor::gearset::green, AbstractMotor::encoderUnits::degrees);
Motor backRightMotor(3, true, AbstractMotor::gearset::green, AbstractMotor::encoderUnits::degrees);
Motor backLeftMotor(4, false, AbstractMotor::gearset::green, AbstractMotor::encoderUnits::degrees);
ADIEncoder leftEncoder('C', 'D');
ADIEncoder rightEncoder('A', 'B');
ADIEncoder middleEncoder('E', 'F');
std::shared_ptr<OdomChassisController> chassis = ChassisControllerBuilder()
.withMotors(frontLeftMotor, frontRightMotor, backRightMotor, backLeftMotor)
.withMaxVelocity(150)
.withSensors(leftEncoder, rightEncoder, middleEncoder)
.withGains(
{0.0035, 0, 0}, // Distance controller gains
{0.003, 0, 0}, // Turn controller gains
{0.002, 0, 0.00006} // Angle controller gains (helps drive straight)
.withDimensions(AbstractMotor::gearset::green, {{4.0_in, 9.0_in}, imev5GreenTPR})//gearset, diameter, track, ticks
.withOdometry() // use the same scales as the chassis (above)
.buildOdometry(); // build an odometry chassis
std::shared_ptr<okapi::XDriveModel> driveTrain = std::dynamic_pointer_cast<XDriveModel>(chassis->getModel());
Controller master;
void initialize() {//runs when program starts
pros::lcd::initialize();
pros::lcd::set_text(1, "Hello PROS User!");
void disabled() {
chassis->moveDistance(0_in);
}//runs when disabled
void competition_initialize() {}//after initialize before auton
void autonomous() {//after start comp
chassis->moveDistance(3_in);
chassis->stop();
void opcontrol() {//after auton
// assigning the chassis to a X-drive model
driveTrain->setBrakeMode(AbstractMotor::brakeMode::hold);
while (true) {
driveTrain->xArcade(master.getAnalog(ControllerAnalog::leftX),
master.getAnalog(ControllerAnalog::leftY),
master.getAnalog(ControllerAnalog::rightX),
0.3);
pros::delay(20);
