I am using VEX PROS for the first time this year, and I stumbled across Okapi’s ChassisController
, that makes auton much, much easier. However, since the functions run in a closed loop, they don’t see what happens to the robot. In our auton, the robot runs into the goal and sometimes gets turned a little bit. This messes up the whole rest of the auton, and it seems to be random when it happens. Is there any way I can incorporate an inertial sensor into the ChassisController
so that it always turns correctly?
I am aware that you can use rotational sensors on the wheels, but I don’t think that would help. I am working on using the OdomChassisController
to see if that would help, but in the Okapi docs it says
If you are using a ChassisControllerIntegrated, the chassis dimensions will be different than the odometry scales given to withDimensions. This is because ChassisControllerIntegrated still requires scales for the powered wheels, while the tracking wheels have a different set of scales. You will need to pass an extra ChassisScales to withOdometry to specify the scales for the tracking wheels.
I have the measurements for withDimensions
, but what would I have to measure for the “tracking wheels”?
And finally, would using a PID chassis controller fix my problem? I’m not sure what difference it would make, because I think moveDistance()
and turnAngle()
already use a PID controller.
