Omni program
Hi I have gotton a disign and built an omni directional chassis but I need help with the program. It is an x shaped chassis with omni wheels on each end of the x. I would like to make it so that chnl 3 is back and forth, chnl 4 is left and right, top left of that jostick to be diagonal left forward, Top right diagonal right forward and so forth. Also chnl 1 to be left and right. If anyone could help me that would be great thanks. I keep trying to make a code but it never works. I watched smartkid’s turtorial but had some trouble understanding.
P.S. I am using easyc v2 and that is the only program I know how to use/have accsse to.
Hi I have gotton a disign and built an omni directional chassis but I need help with the program. I would like to make it so that chnl 3 is back and forth, chnl 4 is left and right, top left of that jostick to be diagonal left forward, Top right diagonal right forward and so forth. Also chnl 1 to be left and right. If anyone could help me that would be great thanks. I keep trying to make a code but it never works. I watched smartkid’s turtorial but had some trouble understanding.
P.S. am using easyc v2 and that is the only program I know how to use/have accsse to.
Did you place your drive wheels in the X configuration (with the wheels in the 4 corners) or in the + configuration (with one wheel in the front, one in the back, one on the left side and one on the right)?
~Jordan
srry I ment to mention that. The chassis is built in an x formation with an omni wheel on each end of the x.
I would try checking out the EasyC code vexbot posted here: https://vexforum.com/showpost.php?p=92331&postcount=22
And maybe the code jgraber posted here: [https://vexforum.com/showpost.php?p=111487&postcount=93
(Both of these are from Cody aka SmartKid’s thread about holonomic drives.)
Hopefully these will help, but if they don’t just let me know and I could try to help you through it.
~Jordan](https://vexforum.com/showpost.php?p=111487&postcount=93)
Whenever I try and open the program it sais that it is unable to. What should I do? Is there a certain place I save it in I keep trying to save it in projects but I can’t.
Unfortunately I can’t really help you there, as I do not own a copy of EasyC… Maybe someone who does could try to help out here? Otherwise I might try asking that question on the EasyC Technical Support Q&A.
~Jordan
Your post has insufficient detail to be actionable.
Try to open what program?
What is the exact error?
Provide the full path to the file you are trying to open.
If you can find a text or printable version, you will probably learn more by retyping/redragondroppings it yourself.
