one button as two-state switch?
hello, i wanted to clarify whether or not this code would work before running it and possibly damaging the bot. the attempt here is to make it so i can use the 6U vexRT button as an on/of switch for the headlights. instead of using two buttons, one to turn lights on and one to turn lights off, i want a way to make a single button press turn the lights on and keep them on until i press the same button again, which would turn it off. here is my code
int buttonToggleState = 0;
    int buttonPressed = 0;
    while(1)
        // check for a button press only if we are not already pressed.
        if(vexRT[Btn6U]==1)
            if(!buttonPressed)
              // change the toggle state
              buttonToggleState = 1 - buttonToggleState;
              // Note the button is pressed
              buttonPressed = 1;
        else
            // the button is not pressed
            buttonPressed = 0;
	// Now do something with our toggle flag
        if(buttonToggleState)
            motor[port9] = 127;
        else
            motor[port9] = 0;
I don’t think you’ll hurt anything on your robot to try it. The only thing I see as a potential problem with your code is you have no wait delay in the loop, so a single button press might switch the state several times if it is held down long enough for the loop to return on itself.
It also is probably more complex then it needs to be. This is just pseudocode, but something like this I think would also work:
toggle = 0
While loop:
	if buttonbeingpressed:
		if toggle == 0:
			turn on light
			set toggle to 1
		else:
			turn off light
			set toggle to 0
	wait 100 ms
		if(vexRT[Btn6U] == 1){
			if(!toggle){
				toggle = true;
				//Change your variable here
		if(vexRT[Btn6U] == 0){
			if(toggle){
				toggle = false;
Outside of the while loop define toggle as a bool.
This was the code we used last year for a 1 button toggle for the mobile goal.
It is pretty small and optimized imo.
bool lightsOn = false;
while (true){
    if (vexRT[Btn6U] == 1){
        lightsOn = !lightsOn;
        if (lightsOn){
            //Turn lights on
        else{
            //Turn lights off
    sleep(100);
You could also do this
Neither of these solutions is valid. The button press would usually last far longer than a mere 100 ms, and, thus, these suggestions would cycle the light on and off repeatedly until the button is released and not even guarantee that the light’s final state is different from the initial state.
@nnolte The programs posted by @LauraDarkez318 and @majorjoel2 do not rely on timing at all to operate. They employ definitive, time-insensitive methods of tracking the state of the button across iterations of the infinite loop.
these are confusing to me. can someone explain exactly how the bool works?
all im trying to accomplish is the idea that if i tap the button once, light turns on and stays on. tap it when the lights are on and itll turn them off. like the clicking buttons on things like children’s motorized toys. press it once, it clicks, the toy turns on. click it again and it turns off.
A bool is either true(1) or false(0)
so how would the code you suggested work with the bool.
when the button is pressed it sets lightsOn to the opposite of itself, so if it was false it sets it to true
then it checks if its true and if it is it turns the lights on
if it’s not true it turns the lights off
so if the button is tapped once, itll stay on until i tap it again and vise versa? also what is with the sleep timer of 100 miliseconds
yes
whats with the sleep 100 mseconds
But like @Barin pointed out the button could be pressed for more than 100ms which would keep toggling it while you hold it down
but if you do something like this
it doesn’t matter how long you press the button for
bool lightsOn = false, pressed = false;
while (true){
        if (!pressed){//if button has not previously been pressed
            lightsOn = !lightsOn;//sets lightsOn to the opposite of itself
            pressed = true;//button has been pressed
    if (vexRT[Btn6U] == 0){ pressed = false; }//button has been released
    if (lightsOn){//if lightsOn is true
        //Turn lights on
    else{//if lightsOn is false
        //Turn lights off
so if i use the code you just sent it wont toggle until i release the button?
Let’s first note that @LauraDarkez318 's code is good as is and is better than some of these other suggestions, as @Barin said. I’ll explain why more clearly:
This is not actually true. Sure, there is no delay, so if you’re running more than this you might eat processor time that could be devoted to other tasks. But for just this piece of code, it works properly. What you’ve missed is the two int’s instead of one. Here are the possibilities:
motor stopped, button becomes pressed:
buttonToggleState = 0, buttonPressed = 0
!buttonPressed = true
both become = 1
motor set to 127 (turns on)
motor running, button stays pressed:
buttonToggleState = 1, buttonPressed = 1
!buttonPressed = false
motor set to 127 (stays on)
motor running, button is released:
buttonPressed becomes = 0
motor running, button becomes pressed:
buttonToggleState = 1, buttonPressed = 0
buttonToggleState becomes = 0, buttonPressed becomes = 1
motor set to 0 (turns off)
motor stopped, button stays pressed
buttonToggleState = 0, buttonPressed = 1
motor set to 0 (stays off)
motor stopped, button is released
Honestly, use your own code. Unless there is a little typo with a bracket or a semicolon or something which I missed, it will work perfectly. The good thing about this is you know why you wrote it that way, so you understand it well. It’s not bad to understand someone else’s code, but yours is better than half the replies.
it would toggle when you press the button down
which code is better to use in terms of the processor? im going to be running a variety of tasks and i dont want to burn anything out, especially not the processor in the microcontroller cortex
