Hi. I am trying to make button L1 for example close my pneumatic claw, and then I click button L1 again to open it. Is this possible, and if so does anyone have any examples? I have searched around, but could not find anything. Thank you!
How To Code a Toggle
This post talks about how to code a toggle in VEXCode:
From that, the toggle code is as such:
bool toggleEnabled = false; // two-choice toggle, so we use bool
bool buttonPressed = false; // IGNORE, logic variable
while (true){
bool buttonA = Controller1.ButtonA.pressing();
// Toggle Logic
if (buttonA && !buttonPressed){
buttonPressed = true;
toggleEnabled = !toggleEnabled;
else if (!buttonA) buttonPressed = false;
// Code For toggle Enabled or Disabled
if(toggleEnabled){
// Do another thing
else{
// Do initial thing
You can find more information about toggles by using the search bar:
How to setup pneumatics in motors and sensors setup
How to Code Pneumatics
piston.set( true );
and
piston.set( false);
Putting it all together
while (true){
// Toggle Logic
if(toggleEnabled){
piston.set(true);
else{
piston.set(false);
Thank you so much. You are so helpful!
Anytime!
In the future when you ask a question and someone answers it, make sure to mark their response as a “Solution” to let others know that an answer has been posted (plus it is a good motivator for people who spend time trying to respond to continue helping the forum).
Ok. I added it to yours. Would a velocity toggle work in the same way? Like the same button Pressed part but the last part to
If (ButtonPressed) {
Wheels.setVelocity(100) } else {
Wheels.aetVelocity(200) };
I know that is not the right format. I just wrote it straight to the forum. Would that work for wheel velocity slowdown toggle?
Yes, that should work perfectly fine based on what I see in the code and context
Ok. Thank you. Sorry for the confusing questions
