Optical shaft encoders too slow?
Hey guys I’ve been having problems with the PID on my conveyor. It moves fine when handled by an operator but when it is set to a pre-set value it starts to drift each time I try it. For instance if I started the conveyor at 0 and then set the conveyor input to -950 it moves to around -970, which is close enough. However if I move the conveyor back to 0 and then try the -950 pre-set again it goes to (-970)-(-1000) but in reality it’s moved down to -1100. If I keep going to 0 then -950 the keeps building, the optical shaft encoder thinks it is at -970 but really it just keeps going past increasing by -100 each time-ish. I tried going the other way (going to -1500 and going back to -950) and it does the same thing but increase by +100. I’m wondering if possibly we stripped the gears but I doubt it. Additionally I’m wondering if possibly the quad encoders are missing steps? I always start the conveyor in the same position every time. Here is the code.
#include "Main.h"
void OperatorControl ( unsigned long ulTime )
      float error;
      int btn;
      int pot;
      int btn2;
      int input;
      float output;
      float dterm;
      int lasterror;
      int btn3;
      int btn4;
      long encoder;
      float errorEncoder;
      float dtermEncoder;
      int lasterrorEncoder;
      float outputEncoder;
      int inputEncoder;
      int btn5;
      int btn6;
      float x;
      int preset;
      InitLCD ( 1 ) ;
      SetLCDLight ( 1 , 1 ) ;
      StartQuadEncoder ( 1 , 2 , 0 ) ;
      PresetQuadEncoder ( 1 , 2 , 0) ;
      input = 250 ;
      inputEncoder = 0 ;
      while ( 1 ) // Insert Your RC Code Below
            if ( (btn == 0) & (btn ==0) )
                  x = 3 ;
            btn = GetJoystickDigital ( 2 , 6 , 2 ) ;
            btn2 = GetJoystickDigital ( 2 , 6 , 1 ) ;
            pot = GetAnalogInput ( 1 ) ;
            if ( btn == 1 ) // Lift PID start
                  input = input + 4 ;
                  if ( input > 770 )
                        input = 770 ;
                  Wait ( 15 ) ;
            else if ( btn2 == 1 )
                  input = input - 4 ;
                  if ( input < 250 )
                        input = 250 ;
                  Wait ( 15 ) ;
            btn3 = GetJoystickDigital ( 2 , 8 , 3 ) ;
            if ( btn3 == 1 )
                  input = 312 ;
                  inputEncoder = -950 ; // This is the line that sets the input on the conveyor to the pre-set
            btn4 = GetJoystickDigital ( 2 , 8 , 1 ) ;
            if ( btn4 == 1 )
                  input = 250 ;
            error = (input - pot) ;
            dterm = error - lasterror ;
            lasterror = error ;
            output = (0.6 * error) + (0.4 * dterm) ; // Output Lift
            if ( output > 127 )
                  output = 127 ;
            else if ( output < -127 )
                  output = -127 ;
            SetMotor ( 8 , -output ) ;
            SetMotor ( 9 , output ) ;
            SetMotor ( 4 , output ) ;
            SetMotor ( 5 , -output ) ; // Lift PID end
            encoder = GetQuadEncoder ( 1 , 2 ) ; // Encoder PID start
            btn5 = GetJoystickDigital ( 2 , 5 , 2 ) ;
            btn6 = GetJoystickDigital ( 2 , 5 , 1 ) ;
            if ( btn5 == 1 )
                  inputEncoder = inputEncoder + 4 ;
                  Wait ( 5 ) ;
            else if ( btn6 == 1 )
                  inputEncoder = inputEncoder - 4 ;
                  Wait ( 5 ) ;
            errorEncoder = (inputEncoder - encoder) ;
            dtermEncoder = errorEncoder - lasterrorEncoder ;
            lasterrorEncoder = errorEncoder ;
            outputEncoder = (0.4 * errorEncoder) + (0.6 * dtermEncoder) ; // Output Encoder
            if ( outputEncoder > 127 )
                  outputEncoder = 127 ;
            else if ( outputEncoder < -127 )
                  outputEncoder = -127 ;
            SetMotor ( 6 , -outputEncoder ) ; // Encoder PID end
            Arcade4 ( 1 , 3 , 1 , 3 , 7 , 1 , 10 , 0 , 0 , 1 , 0 ) ;
            JoystickToMotor ( 1 , 4 , 2 , 0 ) ;
            Wait ( 1 ) ;
Check the inside of the sensor to make sure there isn’t much dust. While I personally haven’t had problems with dust, I know a few teams who blow air in them to clean them out every few matches.
I suggest the same thing. Even if you have run your robot in a dust-free environment, I think sometimes friction within the encoder can cause internal plastic parts to rub that will sometimes create small amounts of plastic dust, and this dust seems to cause a loss in encoder counts.
See this:
https://vexforum.com/t/optical-encoder-failure-mode-self-made-dust/26404/1
Also, I don’t know how your robot is designed, but is it necessary to have the conveyor operate with PID? I know many designs have lifts that can benefit from PID, but are you sure your conveyor needs it?
Yeah the PID was pretty necessary. Our solution was just to slow the lift down and allow the encoder to catch up.
