Our Bot can only read first line of code
Our bot can only read the first line of code:
#pragma config(Motor, port1, WheelLeft, tmotorVex393_HBridge, openLoop)
#pragma config(Motor, port2, Intake, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port3, ScissorLift, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port4, ScissorLift, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port10, WheelRight, tmotorVex393_HBridge, openLoop)
#pragma platform(VEX)
//Competition Control and Duration Settings
#pragma autonomousDuration(20)
#pragma userControlDuration(120)
#include “Vex_Competition_Includes.c” //Main competition background code…do not modify!
// Pre-Autonomous Functions
// You may want to perform some actions before the competition starts. Do them in the
// following function.
void pre_auton()
// Set bStopTasksBetweenModes to false if you want to keep user created tasks running between
// Autonomous and Tele-Op modes. You will need to manage all user created tasks if set to false.
// Autonomous Task
// This task is used to control your robot during the autonomous phase of a VEX Competition.
// You must modify the code to add your own robot specific commands here.
task autonomous()
// User Control Task
// This task is used to control your robot during the user control phase of a VEX Competition.
task usercontrol()
while (true)
	// Movement
	motor[port1] = vexRT(Ch2Xmtr2);
	motor[port10] = vexRT(Ch3Xmtr2);
	motor[port2] = vexRT(Ch2);
	motor[port3] = vexRT(Ch2);
	motor[port4] = vexRT(Ch3);
vexRT is an array, not a function.
Just to clarify ruiqis post.
The () should be ]
