I am competing in the VEX Nothing but net compitition and my robot is a corner shooter looking at a 60degree angle but I need to turn my fly week to 54% power to make it in high i feel that if i make a timer in the code to put the shorter on full power then overfeed the balls at a specific rate so the shooter can use its full power and i can have a high rate of fire. the mock code I have now goes a little like this
int n=0;
while 1==1
if (vexRT[Btn8U] == 1) //Button to activate the over feed mode
nMotorEncoder[tl] = 0
wait1Msec(50)
n = nMotorEncoder[tl]
if (n > 10)
motor[port10] = 127;
else
else
motor[port10] = 0;
I’m not quite sure what the question is. If you are asking “will this work?”, then all I can say is it;s a good idea and you need to try it on your robot. The code you posted above may need a little modification to work, try this.
#pragma config(Sensor, I2C_1, , sensorQuadEncoderOnI2CPort, , AutoAssign )
#pragma config(Motor, port10, theMotor, tmotorVex393_HBridge, openLoop, encoderPort, I2C_1)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task main()
int n=0;
while(1)
nMotorEncoder[theMotor] = 0;
wait1Msec(50);
n = nMotorEncoder[theMotor];
if (n > 10)
motor[port10] = 54;
else
// Power boost
else
motor[port10] = 0;
wait1Msec(10);
You will have to figure out the threshold for “n” by trial and error. Perhaps make n a global variable so you can see it in the debugger window.
