We got our field pretty early relative to many teams. So, in an effort to help the community answer any questions about the Over Under field, we made this video. If you have any questions feel free to ask.
Thank you so much for this! I find this very beneficial!
Also quick question: you meant Rouleaux Tetrahedron instead of Rouleaux Triangle, right?
Yes, rouleaux triangle is the 2d shape. Sorry for the confusion
No need to apologize, and thank you for the correction!
Because the goal flipa up like that, would It be possible for the “under” bot to lift it up? If they could then the goal itself could become a hopper of some kind. But honestly even if they could lift it up it’s probably going to be added to the manual if it isn’t there already
What is the maximum amount of triballs a robot could fit in goal?
From <SG5>:
Note: Directly manipulating the net structure, such as lifting it from the field in an attempt to add
or remove Triballs, could be considered a Violation of <SG3>, <G7>, and/or <S2> at the Head
Referee’s discretion.
While this doesn’t seem like an absolute ban on it, it seems like you are very likely to get DQed or otherwise penalized if you try it.
