Hello vex community i was looking at the rules and it said one micro controller is allowed. So am i right to assume by this rule that we will not be able to use a partner controllers.
By one microcontroller it means one V5 Brain. There are no more partner controllers, but you can use two “main” controllers. If you have the Cortex, you can use the partner controller with it.
The microcontroller the rules are referring to is the V5 brain, cortex, or PIC, not the joystick. You can use two v5 controllers to enable two driver control.
Only one Cortex or V5 brain.
@The Electrobotz thank you
