So my team is considering using a partner joystick because we need more buttons. Is it possible to program different functions for the same buttons on the partner joystick?
I assume (…) by “same buttons” you mean “same button but on separate joystick”, and you can simply use
Btn6UXmtr2
to reference it~
There are a few posts about this …and i suggest you to go check them out:
Running two controllers via the Partner Port
