Partner Joystick
If you have the required cable to connect a VEXNet joystick to a Partner Joystick, could you use the cable to connect two VEXNet joysticks together for the same function, but only using a VEXNet Key in one controller? Sorry if that was confusing, but it’s a vital question for a serious problem our bot is facing.
Hello Thane,
Thanks for taking the time to visit our forum.
Yes, you can use the same cable from partner port to partner port. Its the 276-1602 Coiled Handset Cable (also available at retail).
Regards.
-Eli
