New ratchet design. No rubberbands. Extremely strong. Inspired by a lawn mower recoil start mechanism. Extremely little parasitic friction when freewheeling.
Standard def video available. HD is still processing…
This has been built & tested on the workbench. Real-world feedback appreciated.
Still working on a completely silent version…
In case you can’t tell… those are 36 and 60 tooth gears, perfect for a 3000 rpm flywheel.
You mentioned in the video that it should work pretty well with a second mechanism for motion in the other direction. I can confirm that it does indeed work well.
Hard to ‘see’ friction when attached to a motor that’s reversing direction. Better way would be to check motor watts, but even that will be exceptionally low due to it being only a standalone mechanism.
Both mine and his are proof of concepts. Take them, build them, understand them, learn from them, and see if you can improve them.
im looking into testing a mechanism like this for our flywheel / intake which of course needs to be ultra low friction so i was wondering is their any easy way to make the ratchet part?
It took <3 mins to make the ratchet. I assume you watched the video? Just take some aluminum, cut it to slightly fit, sand it, bend it sideways a little, and you’re done.
Once you have the cut piece in front of you it should be apparent how it works.
My hand is putting a tiny bit of pressure on the gears. There is a little drag on the gears and the free gear does start to spin a bit if there is not some resistance, but there is very little drag. (It was small enough that I felt that if I added a single driven wheel to each side it would not move.) I’ll try to get a video of it later that shows the drag when I’m back in the robotics room.
There is no way to remove all the drag, but it could be minimized.
Tweaking the shape might reduce contact between the catch and the gears when spinning freely.
The nylocks might be rubbing a bit on the inside of the 60T gears. I added a thin spacer, but It may not have been enough (already used thin nylocks). I considered sanding the rib lines on the gear face, but this was a quick prototype.
There will be drag from the axle and the round insert on the gears.
Note, I did not use any lubricant.
Also…
Depending on how the gears stop, its possible that both 60T gears spin free when the 36T gear is stationary. This is built so that only the 36T gear in the middle is locked to the axle. When it spins in one direction, inertia (centrifugal force) causes one of the locks to swing out and engage one of the 60T gears. When the 36T spins the other way, this lock returns towards the center and the other lock moves out to engage the 2nd 60T gear. If the 36T gear is not spinning, then it may or may not be engaged with the 60T gears - it basically depends upon orientation, gravity, and dumb luck.
I encourage you to build something similar and experiment. I purposely didn’t show too much detail and just wanted to get the idea out there.
All I did was watch the video and try it. The “hardest” part was checking the fit, filing a touch more and repeating. That prototype took a little over an hour of fiddling around, most of it because my fingers are to big and I was playing with the spacing.
