Pd drive function with distance sensor?
so ive been messing around with a distance sensor trying to see if i can set my target distance as whatever the sensor reads and was wondering if what im doing is right.
this is the code i threw together using my pd function
//this drives to whatever its lined up with and grabs it
//pd drive (with distance sensor)
void pdrivedis(double maxdist) {
double targetDistance=claw_dis.objectDistance(mm)-claw_mogo_dis;
double error = targetDistance - (lf.position(degrees)*tank_ratio);
double previousError = error;
double currentDistance= (lf.position(degrees)*tank_ratio);
while (std::abs(currentDistance)<std::abs(maxdist)) {
Brain.Screen.setCursor(1, 1);
Brain.Screen.print(error);
currentDistance = (lf.position(degrees)*tank_ratio);
error = targetDistance - currentDistance;
double derivative = error - previousError;
double speed = driveKp*error + driveKd*derivative;
set_tank(speed, speed);
if(claw_dis.objectDistance(mm)<claw_mogo_dis) {//checks for a mogo
  break;
vex::task::sleep(10);
i dont know if this would work, is there any better way i could do this?
Can you send your code? Make sure to put it in code tags
[Code]
Put your code here
[/Code]
Make sure the lines with [Code] and [/Code] are empty.
Formated code for everyone else
